This is a section of the DME harness from my 1987 3.2. Pictured are
1) 6 pin connector that plugs into the sub harness for alt/starter/reverse light
2) O2 sensor
3) a rubber relay socket
4) a single black and a single green wire with eyelet terminals
I'm assuming that the O2 sensor and the other wire go thru the sheet metal to the exhaust area. I don't know what the green and black wires go to. The relay socket is easy. Do you guys know before I have to hunt it down. I haven't been able to find a good harness diagram that has good enough resolution to print out.
Thanks
DaveClick to view attachment
