Drive by wire, getting rid of another cable, Electronic pedal, not a wa wa |
Gunn1 |
Nov 24 2016, 10:41 AM
Senior Member Group: Members Posts: 1,021 Joined: 14-February 16 From: Minnesota Member No.: 19,670 Region Association: None |
Anyone have a drive by wire set up on their 914? Looking for a cable-less solution to throttle control. Would be for a stock 75' 914 2.0liter. (IMG:style_emoticons/default/driving.gif)
jim_hoyland |
Nov 24 2016, 10:49 AM
Get that VIN ? Group: Members Posts: 9,298 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Anyone have a drive by wire set up on their 914? Looking for a cable-less solution to throttle control. Would be for a stock 75' 914 2.0liter. (IMG:style_emoticons/default/driving.gif) That would be BIG ! (IMG:style_emoticons/default/smile.gif) |
bandjoey |
Nov 24 2016, 10:53 AM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Sounds like get rid of 1 cable to add 30 electric wires a computer and an electric server motor.
Gunn1 |
Nov 24 2016, 10:59 AM
Sounds like get rid of 1 cable to add 30 electric wires a computer and an electric server motor. No, don't think so. pedal with a transmitter and power supply, and a actuator motor with receiver mounted on the TPS with a power supply. Think the complexity is in the electronics. (IMG:style_emoticons/default/popcorn[1].gif) |
bandjoey |
Nov 24 2016, 11:28 AM
Bring it on. This could be your claim to fame. Will b watching this. (IMG:style_emoticons/default/smash.gif)
stugray |
Nov 24 2016, 11:29 AM
This would be low complexity.
One arduino module (about $10, the size of a postage stamp) one variable resistance throttle pedal (Guido Simplex sells these) or a PWM model from modern car would work too, and one servo motor. The arduino would read the potentiometer (resistance) via an analog channel (or the PWM signal via digital channel). It would then drive one of it's outputs with another PWM signal to the servo motor. The servo motor only requires power in and the PWM signal to command a position. There would be a tiny amount of code in the arduino to "smooth" the signal but it would be trivial. You just want to find a servo that has no problem driving the throttle input |
Chris914n6 |
Nov 24 2016, 12:11 PM
Jackstands are my life. Group: Members Posts: 3,320 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
I've done the opposite on a 350z motor. What do you hope to gain?
Gunn1 |
Nov 24 2016, 12:20 PM
Mueller |
Nov 24 2016, 12:43 PM
This would be low complexity. One arduino module (about $10, the size of a postage stamp) one variable resistance throttle pedal (Guido Simplex sells these) or a PWM model from modern car would work too, and one servo motor. The arduino would read the potentiometer (resistance) via an analog channel (or the PWM signal via digital channel). It would then drive one of it's outputs with another PWM signal to the servo motor. The servo motor only requires power in and the PWM signal to command a position. There would be a tiny amount of code in the arduino to "smooth" the signal but it would be trivial. You just want to find a servo that has no problem driving the throttle input The 2 Audi gurus that have done this conversion to their 914s would know best, but I am pretty sure the pedal has 2 pots, one +5vdc and one -5vdc or something like that, redundancy in case something goes wrong. This is one of those projects that if you cannot figure out on your own you shouldn't be doing it, other peoples lives are at stake. |
Rand |
Nov 24 2016, 01:23 PM
Don't feed the troll
Elliot Cannon |
Nov 24 2016, 01:27 PM
I'm a big believer in keeping things simple but I encourage people to do things like this. Sounds like a good project. However if you start something like this keep us all posted on the results.
ConeDodger |
Nov 24 2016, 01:32 PM
Apex killer! Group: Members Posts: 23,588 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Bring it on. This could be your claim to fame. Will b watching this. (IMG:style_emoticons/default/smash.gif) Oh come on. He already has a claim to fame. (IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/happy11.gif) |
Mikey914 |
Nov 24 2016, 01:41 PM
The rubber man Group: Members Posts: 12,668 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Sometimes best to keep it simple. Remember aircraft now use this feature in most production today. But , hundreds of millions of dollars went into design, and here's the real key .........Redunancy!
If you get into an accident and there's any possibility this apparatus could even be thought to have been involved, your hosed. |
Gunn1 |
Nov 24 2016, 02:57 PM
Your probably right, must likely the reason there is not a plug and play kit available. I'm not a liability attorney, but couldn't the same be said for some non factory modifications that potentially caused the accident.
Elliot Cannon |
Nov 24 2016, 03:19 PM
"Open the pod bay doors please HAL". "I'm sorry Dave". (IMG:style_emoticons/default/biggrin.gif)
stugray |
Nov 24 2016, 04:21 PM
I knew a brilliant guy at work that would say "you cant TRUST those new-fangled PLCs!" (Programmable Logic Controllers).
I said "Then I guess you never go near factories or power plants or ride on elevators huh?" I just got a blank stare. |
Chris914n6 |
Nov 24 2016, 04:45 PM
I think the tube is just brazed on at the firewall. There is a pic of a cut out tunnel floating around somewhere that would help.
For some good reading... Nissan FSM. Any of the 350z would be a good choice as they have specs. 0-5v and a redundant sender on the pedal. Wires to the ECU so off hand I don't think one will control the other without a translator (ECU). eGas is a Bosch tech so most, if not all, of it should be compatible. |
Mueller |
Nov 24 2016, 05:59 PM
Your probably right, must likely the reason there is not a plug and play kit available. I'm not a liability attorney, but couldn't the same be said for some non factory modifications that potentially caused the accident. https://m.summitracing.com/parts/lok-xdbw-6...kxbEaAtAp8P8HAQ Plus you need another module that cost $300+ .... see tab for other parts So yes it can be done with properly engineered parts. |
stugray |
Nov 24 2016, 06:22 PM
The project for a variable resistor type pedal is one of the most basic tutorials for an arduino:
https://www.arduino.cc/en/Tutorial/Knob and is literally 10 lines of code If you used the other type of gas pedal (PWM) & I had to read the PWM signal, it would be slightly more complicated as I would need to use one of the digital inputs to determine the pulse width from the pedal |
jd74914 |
Nov 24 2016, 06:48 PM
This is one of those questions where if you have to ask you really shouldn't be doing it...
The difference between an arduino and PLC is the hardened electronics. The coding is trivial, but I would really not trust the reliability of an ardiuno in a life or death application. My car is going to DBW with an aftermarket engine controller, but using oem components like BarryM used for his car wouldn't be too hard. |
Lo-Fi Version | Time is now: 17th May 2024 - 11:42 AM |
