OT: Single post 6000 lift?, Anybody have one? What do you think of it |
JRust |
Nov 26 2016, 12:14 AM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
I have a Mid Ride scissor lift which I love. Came across this single post 6000lb lift. First one of these I have seen. Just wondered if anyone has one & had any issues. Can it truly handle the weight with out tipping? What are the negative's with this setup. Only down side with my scissor lift is to pull the motor. You have to get it in just the right spot on the lift. Which is a little off center. Nothing that has been an issue but I like how open & easy this lift would be for that.
Realistically I don't need 2 lifts. So I'd be looking to replace my mid rise with this. Worth doing? |
Mark Henry |
Nov 26 2016, 12:39 AM
The one thing I do like is if you put the post against a wall you still have very usable space under a car.
I have no problem with a well built one post lift. I used to build scissor lifts, but we also made a one post I really liked. Think about how a forklift works, basicly this is what this is. You have to have a good concrete floor, I definitely wouldn't try a lift anything on asphalt. https://www.youtube.com/watch?v=bOVfuWmNgKY |
wndsrfr |
Nov 26 2016, 06:57 AM
Senior Member Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
I have a Mid Ride scissor lift which I love. Came across this single post 6000lb lift. First one of these I have seen. Just wondered if anyone has one & had any issues. Can it truly handle the weight with out tipping? What are the negative's with this setup. Only down side with my scissor lift is to pull the motor. You have to get it in just the right spot on the lift. Which is a little off center. Nothing that has been an issue but I like how open & easy this lift would be for that. Realistically I don't need 2 lifts. So I'd be looking to replace my mid rise with this. Worth doing? If you're going to set your car up for the track with the suspension lowered at all, you'll have to build ramp boards to use the one post.....my ground clearance is about 4 inches....would get hung up on this as pictured. |
Nov 26 2016, 07:58 AM
914-6 GT in waiting Group: Members Posts: 19,279 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
The nice thing about buying a lift for a 2k lb car is almost anything will work. If your going to use it for other modern cars like heavy trucks you have to look hard at the specs.
Mark Henry |
Nov 26 2016, 08:00 AM
If you're going to set your car up for the track with the suspension lowered at all, you'll have to build ramp boards to use the one post.....my ground clearance is about 4 inches....would get hung up on this as pictured. I watched another vid on YT and this thing rolled around like a pallet truck, easy on a smooth floor. So lowered car you could put the wheels on 4"blocks (small removable ramps) and roll the lift under the car. Another option is to sink this into the floor. |
JRust |
Nov 26 2016, 10:24 AM
If you're going to set your car up for the track with the suspension lowered at all, you'll have to build ramp boards to use the one post.....my ground clearance is about 4 inches....would get hung up on this as pictured. I watched another vid on YT and this thing rolled around like a pallet truck, easy on a smooth floor. So lowered car you could put the wheels on 4"blocks (small removable ramps) and roll the lift under the car. Another option is to sink this into the floor. I used ramps for my scissor lift for the height issue. No big deal to work around that. Couldn't do it the same way as this one comes in from the side. Still like the idea of having the bottom of the car completely open to roll under. The only downside with the scissor lift. Not critical as you really don't have anything in the middle of your car but the floor pans. LOL! Still would be nice. Think I may try to make a deal with the guy. If it doesn't work out I'm perfectly happy with my scissor lift. This just looks even easier to move around if I need to. I'm going to email the guy & we'll see |
wndsnd |
Nov 26 2016, 01:33 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
Personally, I don't get it. Unless it is really cheap.
If you bought a sissor lift you probably have height restrictions. The whole arm part of that lift just looks complicated. Look at the MaxJax. You will have access to everything under the car. Engine Drops, Tranny drops, no problem. It has limited lift height, approx 4 feet or so, but I have found it ok. I just roll around on the little stool and everything is fine. The stool also has little parts and tool holders so everything is convenient. I purchased one and had it professionally installed. At first the motor/hydraulic unit overheated, so I talked with them. It took a couple of conversations, but they sent me a replacement unit and everything now works like a charm. Some mount the power unit on a wall or post, but I did not feel the need. Honestly you hear people say it was the best garage decision and I agree. I pretty much have the car up after every trip and it is a relief to be able to check every thing over and tend to any need. |
rick 918-S |
Nov 26 2016, 01:54 PM
Hey nice rack! -Celette Group: Members Posts: 20,463 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I like that but could t justify the cost for a hobby so I build this. 2500 lb. air bumper jack. It lifts a shell like its nothing.
I need a side lift to mount cars on the Celette. I could use a two post but is have I floor heat tubes in my shop. Can't drill holes in the floor to secure the posts. I can roll this around with the car on the lift. |
JRust |
Nov 26 2016, 08:25 PM
It sold before I could get to it (IMG:style_emoticons/default/sad.gif) . Oh well my scissor lift does everything I need anyway. Just like the accessibility & movability a little more with this one. It was $1400 & I was hoping to make a trade with him for a motorcycle I have. Thanks for all the input guys (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 21st May 2024 - 12:27 AM |
