FS: Custom axles for Boxster 5 speed transaxle in 914, Using Boxster CV's and stock 914 arms/bearings |
precisionchassis |
Nov 27 2016, 01:09 PM
Member Group: Members Posts: 99 Joined: 26-July 10 From: Gilbert, AZ Member No.: 11,979 Region Association: Southwest Region |
The last time I did a Subaru powered 914, I used a Boxster 5 speed transaxle. and had an extra pair of axle shafts made as a spare. I never needed them and I've since closed down my shop, so I have these axles available for anybody interested.
For those that don't know, the Boxster (base model) and the 914 share the same rear wheel bearings. What this means is that you can use the Boxster wheel hub, and stub axle in the 914 trailing arm, which also means you can use the Boxster CV joints IF you have these custom axle shafts to go with them. What you also might not know is that the Boxster cable shifter will work in the 914 chassis without the need for custom cables. Also, a number of Audi engines bolt directly to the Boxster transaxle without the need for any adapter plate or custom flywheel. Asking $200 for this pair of axles. (IMG:http://www.914world.com/bbs2/uploads_offsite/i180.photobucket.com-11979-1480273745.1.jpg) Anyone interested should contact me via email at precisionchassis@gmail.com for the fastest response. |
Chris914n6 |
Nov 27 2016, 05:22 PM
Jackstands are my life. Group: Members Posts: 3,320 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
What year Boxsters?
I looked at one at the wrecker and the stub looked like it had the CV built in, no bolts. Is it because it was auto? |
Lo-Fi Version | Time is now: 19th May 2024 - 01:43 PM |
