Mystery wires, What is this? |
slotty008 |
Dec 1 2016, 03:54 PM
Member Group: Members Posts: 191 Joined: 11-November 15 From: Belgium Member No.: 19,349 Region Association: None |
Does anyone know what the purpose is of these 2 steel wires on the centere tunnel in front of the throttle pedal?
7TPorsh |
Dec 1 2016, 03:57 PM
Looks like cut clothes hangers.....PO (Previous Owner) Clamp
Dec 1 2016, 04:03 PM
Home made "fix" for a broken lose clutch tube ...
(IMG:style_emoticons/default/dry.gif) |
dlee6204 |
Dec 1 2016, 05:18 PM
iankarr |
Dec 1 2016, 06:13 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Yep. If your car shifts inconsistently and the clutch pedal is mysterious, that's why. Fortunately it's a pretty simple fix. Especially if the clutch tube weld at the firewall is still intact. |
slotty008 |
Dec 2 2016, 01:26 PM
(IMG:style_emoticons/default/agree.gif) Yep. If your car shifts inconsistently and the clutch pedal is mysterious, that's why. Fortunately it's a pretty simple fix. Especially if the clutch tube weld at the firewall is still intact. The weld at the firewall is not intact , so how do I fix it? I must say I have no real problems shifting. |
TheCabinetmaker |
Dec 2 2016, 01:37 PM
If it shifts ok then just drive it till it doesn't. Not the nicest looking fix, but it should hold as well as anything else.
barefoot |
Dec 2 2016, 02:17 PM
Senior Member Group: Members Posts: 1,274 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
(IMG:style_emoticons/default/agree.gif) Yep. If your car shifts inconsistently and the clutch pedal is mysterious, that's why. Fortunately it's a pretty simple fix. Especially if the clutch tube weld at the firewall is still intact. The weld at the firewall is not intact , so how do I fix it? I must say I have no real problems shifting. My clutch tube had been repaired at the firewall with a thicker plate welded to the tube then screwed to the firewall. When I removed the shifter starting some restoration, I noticed that the clutch tube had been on the wring side of the shift link and had a groove worn into it. Bu cutting an access port forward of the shifter, i devised a clamp fashioned form an electrical clamp and bolted the tube down tight in correct position, it aint going nowhere now. There are other posts that show where to cut openings. |
walterolin |
Dec 2 2016, 02:25 PM
Senior Member Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
Here are some threads about clutch tubes:
http://www.pelicanparts.com/techarticles/9...nter_tunnel.htm http://www.914world.com/bbs2/index.php?showtopic=298186 http://www.914world.com/bbs2/index.php?sho...;hl=clutch+tube You can Google "914world clutch tube" and find some more. |
slotty008 |
Dec 3 2016, 01:58 AM
Thx for all the replies guys. I'm going to the garage today and put the car on the lift to see what we can do about the firewall side. The tube itself feels rather stable at the moment but for how long?
Lo-Fi Version | Time is now: 17th May 2024 - 08:48 AM |
