QUOTE(slotty008 @ Dec 2 2016, 02:26 PM)
QUOTE(cuddyk @ Dec 2 2016, 01:13 AM)
Yep. If your car shifts inconsistently and the clutch pedal is mysterious, that's why. Fortunately it's a pretty simple fix. Especially if the clutch tube weld at the firewall is still intact.
The weld at the firewall is not intact , so how do I fix it? I must say I have no real problems shifting.
My clutch tube had been repaired at the firewall with a thicker plate welded to the tube then screwed to the firewall. When I removed the shifter starting some restoration, I noticed that the clutch tube had been on the wring side of the shift link and had a groove worn into it. Bu cutting an access port forward of the shifter, i devised a clamp fashioned form an electrical clamp and bolted the tube down tight in correct position, it aint going nowhere now. There are other posts that show where to cut openings.
