Off idle bog - previously running well, '74 D-Jet FI |
Nogoodwithusernames |
Dec 2 2016, 01:37 PM
Member Group: Members Posts: 237 Joined: 31-May 16 From: Nor-Cal Member No.: 20,051 Region Association: None |
Hey guys, so after replacing all my fuel lines and vacuum lines everything was going great until the fuel tank settled down a bit and pinched the return line somehow causing excessive fuel pressure and popping a line off. Been a while since that but finally got new lines (again) under the tank (I even went stainless braided to help avoid kinks and such) but now I have a major bog as soon as I come off idle. Idle does wander a bit between 1000 and 1500 so I'm thinking vacuum leak but I didn't have any problems previously until finally starting the motor again after re-redoing the front fuel lines.
All vacuum lines are connected, aka no loose vacuum hoses anywhere. Fuel is right at 28 or 29PSI. This is all on a 2l D-Jet system. |
Rand |
Dec 4 2016, 12:40 AM
You installed stainless braided fuel lines to avoid kinks instead of routing them correctly? Because a pinched return line blew a fuel line off? What kind of clamps do you use? Please show us a pic of your fuel pressure gauge setup.
Lo-Fi Version | Time is now: 19th May 2024 - 03:50 PM |
