converting turn signal buckets |
JFG |
Dec 3 2016, 04:32 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I need to split the front turn signal bucket into a clear driving light (side light) and the orange blinker.
I have done this using a capless bulb holder but as it is black and bulky it shows through the clear lens and looks rubbish. So i'm now going to remake the fittings using a BA9s fitting and bulb. I have found a few types, some ceramic or insulated and some with one or two wire connectors. Am i correct in thinking that the single wire non insulated holders will earth through the body of the bucket? leaving just the live to wire up to the loom? |
bdstone914 |
Dec 3 2016, 01:03 PM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I doubt it. The buckets have arubber gasket that isolate them from the body. The only contact the body is rhe end of the U clamp and that area is not bare metal. Better to run a ground wire.
Spoke |
Dec 4 2016, 08:41 AM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
The main bulb in the bucket is a BAY15D dual filament based bulb with bright blinker and low intensity running light.
Bruce is correct about the bucket being insulated except for the bracket holding the bucket to the fender. However the ground for the BAY15D bulb is connected to the bucket and is connected to chassis ground by the connecting wire. Thus the white running light only needs 12V power with its socket attached to the bucket for ground. An extra ground wire is not needed. I thought someone has a kit for doing the dual bulb conversion? You could also do something like this: Attached thumbnail(s) |
JFG |
Dec 4 2016, 09:24 AM
Thanks both for the advice. I had seen a picture with only 1 wire running from the lower fitment which in turn enhanced my confusion.
Liking the led set up. If I had the extra in my budget (hadn't bought other stuff!) I'd have a full set for the car. |
amfab |
Dec 4 2016, 12:43 PM
Member Group: Members Posts: 393 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None |
SKL1 |
Dec 4 2016, 03:37 PM
Senior Member Group: Members Posts: 1,598 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Highy recommend the spoke "fix." Works great, especially for the euro lenses. I first tried the camp kit and was not impressed. (in fact, if I could find them I'd give them away...)
Garland |
Dec 4 2016, 06:13 PM
Restoration Fanatic Group: Members Posts: 1,328 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
SKL1 |
Dec 4 2016, 10:30 PM
When I see some of those pix I can't understand why someone would put the euro lenses on and leave the god awful side markers. Either make it look like the euro car (without the side markers) or leave the US orange lenses... no car ever had the horrible US side markers AND the two bulb system.
Dave_Darling |
Dec 5 2016, 02:51 PM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Remember that the turn signal bucket is plastic, so you're not going to ground anything through that anyway...
--DD |
Lo-Fi Version | Time is now: 6th May 2024 - 07:18 AM |
