FS Gates green stripe 1 1/4" hose, Halfsies anyone? |
Chris914n6 |
Dec 4 2016, 02:44 AM
Jackstands are my life. Group: Members Posts: 3,310 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
See latest post.
----------- On the wish list: Me - Vegas ThePaintedMan - Florida madmax914 - Oregon BigFour1973 - Socal BuddyV - Socal mgp4591 - SLC |
76-914 |
Dec 4 2016, 12:05 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
50ft box about $185-190 at the usual online places. Half is a little more than needed but it's cheaper than local by a bunch. Shipping either to or from Las Vegas 89121. Not in a hurry but do need to install it before April. Ahah! That means you'll be at Rt 66. (IMG:style_emoticons/default/piratenanner.gif) |
Chris914n6 |
Dec 19 2016, 08:34 PM
bi-monthly (IMG:style_emoticons/default/icon_bump.gif)
ThePaintedMan |
Dec 20 2016, 08:40 AM
Advanced Member Group: Members Posts: 3,885 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Sounds good to me Chris. I need to buy some for the EG33. I'm pretty sure 1 1/4 is what I need.
madmax914 |
Dec 20 2016, 01:01 PM
Member Group: Members Posts: 204 Joined: 16-February 14 From: Salem, Oregon Member No.: 17,007 Region Association: Pacific Northwest |
Chris, who are you buying it through? I'll be needing some her shortly.
BigFour1973 |
Dec 20 2016, 01:32 PM
Member Group: Members Posts: 187 Joined: 16-November 14 From: Long Beach Member No.: 18,126 Region Association: Southern California |
Chris, who are you buying it through? I'll be needing some her shortly. https://www.amazon.com/Gates-28445-Heater-Hose/dp/B000CRHLF8 Madmax914- Id be up to go halves on one of these with you. 50ft roll 1 1/4 |
BuddyV |
Dec 20 2016, 01:47 PM
Robert Group: Members Posts: 555 Joined: 8-April 05 From: Santa Rosa, CA Member No.: 3,898 Region Association: Northern California |
Is this for a SBC V8 application?
.... if so, I would be in for half an order. I have some old hose in my used kit..... probably best to start fresh. (IMG:style_emoticons/default/beerchug.gif) |
Chris914n6 |
Dec 22 2016, 11:58 PM
I forgot to sub to my own thread (IMG:style_emoticons/default/sad.gif)
Rockauto currently $172.50 + $10 shipping. It usually comes out of Phoenix for me so no tax. West coast obviously cheaper for reshipping. I need to also get a 1.25" to 1.5" flex hose after I figure out which length fits better, so I figured I'd order it. Probably in a week or two. Doesn't matter to me where the other half goes if the coastal guys want to wheel and deal with each other. As long as I don't have to hold on to it for too long. |
Chris914n6 |
Dec 23 2016, 12:03 AM
Is this for a SBC V8 application? .... if so, I would be in for half an order. I have some old hose in my used kit..... probably best to start fresh. (IMG:style_emoticons/default/beerchug.gif) i think the RH kit does 1" in and 1.25" out, about 10ft each way. Depends on you rad and fittings if 1.25" makes sense. |
mgp4591 |
Dec 23 2016, 12:50 AM
914 Guru Group: Members Posts: 5,368 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
I'm up for splitting an order with someone. I'd volunteer to drive down to Vegas Chris, but you remember how the last trip went... (IMG:style_emoticons/default/blink.gif)
Chris914n6 |
Feb 18 2017, 12:26 AM
Got my box of hose.
Box size 28 x 28 x 8 & 15 lbs. Might be able to get it in a smaller box once I get my half pulled out, but it doesn't bend so good. Fedex Ground to FL ~ $54 SLC Utah ~ $27 That's with my account. Honestly, more than I expected. Half of $172.50 for 25ft plus shipping, or maybe 2x 13ft. Can bring to Route66 or hold if someone is driving thru Vegas. My 35mm/ 1 3/8" Toyota rad and Nissan engine outlets needed lube to get it on, so not quite a good fit like someone had led on (IMG:style_emoticons/default/poke.gif) |
mgp4591 |
Feb 18 2017, 04:17 AM
Chris, let me make some measurements to see if it will fit my radiator without killing it. I should be able to get to it tomorrow and let you know.
dyckster |
Feb 18 2017, 09:37 AM
Newbie Group: Members Posts: 22 Joined: 9-April 16 From: prairies Member No.: 19,881 Region Association: None |
I'm interested in 20feet or so. montana
timothy_nd28 |
Feb 18 2017, 08:57 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
If the above falls through, I'll buy your other half.
mgp4591 |
Feb 22 2017, 11:32 PM
PM sent...
Chris914n6 |
Mar 5 2017, 10:57 PM
Sold to Mike - mgp4591 whatever that means (IMG:style_emoticons/default/poke.gif)
Lo-Fi Version | Time is now: 5th May 2024 - 09:45 AM |
