WTB: 1.7L Fuel Injectors |
dlee6204 |
Dec 4 2016, 05:27 AM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
I'm looking for at least 2 (but will buy more) 1.7L yellow injectors. I plan to send them off to be clean and test so they don't have to be new. Thanks.
mramber |
Dec 4 2016, 08:03 AM
Member Group: Members Posts: 87 Joined: 14-April 13 From: Minneapolis, MN Member No.: 15,768 Region Association: Upper MidWest |
I'm looking for at least 2 (but will buy more) 1.7L yellow injectors. I prefer untested cores as I will send them off to be cleaned/ tested but I''m open to whatever you may have. Thanks. I should have 4 in the garage, they would be cores. I can check this morning |
mramber |
Dec 4 2016, 08:09 AM
I'm looking for at least 2 (but will buy more) 1.7L yellow injectors. I prefer untested cores as I will send them off to be cleaned/ tested but I''m open to whatever you may have. Thanks. I should have 4 in the garage, they would be cores. I can check this morning Yep, I have 4, here is a pic of 2 of them. Attached thumbnail(s) |
Dominic |
Dec 4 2016, 11:48 AM
Dominic Group: Members Posts: 991 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
I'm looking for at least 2 (but will buy more) 1.7L yellow injectors. I prefer untested cores as I will send them off to be cleaned/ tested but I''m open to whatever you may have. Thanks. I have 3 used 1.7L core fuel injectors for $15.00 each (free shipping for all 3) Cheers, Dominic |
dlee6204 |
Dec 5 2016, 07:49 PM
I found some injectors. Thanks to all those who offered.
dlee6204 |
Jan 10 2017, 03:18 AM
BillC |
Jan 10 2017, 07:23 AM
Senior Member Group: Members Posts: 536 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
PM sent.
Dominic |
Jan 10 2017, 09:15 AM
Do you need new or used Fuel Injectors? I have both. PM me if you need any.
Thanks, Dominic |
fduval |
Jan 10 2017, 10:06 AM
Newbie Group: Members Posts: 41 Joined: 2-January 13 From: quebec Member No.: 15,331 Region Association: Canada |
bdstone914 |
Jan 10 2017, 10:26 AM
bdstone914 Group: Members Posts: 4,514 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have not had time to look but I am sure I have some 1.7 injectors. I would get at least 6 and send out to a cleaner. Test for pindle movement with power applied. Half of the ones I have are stuck. If you get a larger qty cleaned and checked you can match the closest ones for flow. All about consistency.
Bruce |
Lo-Fi Version | Time is now: 1st May 2024 - 10:33 PM |
