Vacuum leak, Detection |
ricardo |
Dec 4 2016, 09:07 AM
Newbie Group: Members Posts: 47 Joined: 9-November 16 From: Lakeview, NY Member No.: 20,572 Region Association: North East States |
Finally got engine running but I suspect vacuum leaks. Was wondering what the best way is to detect vacuum leaks without a smoke machine? Mi hu
Frankvw |
Dec 4 2016, 04:27 PM
working on my first 914 ! Group: Members Posts: 651 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
for example with a vacuum tester tool. You can find them under 20 bucks which will be fine to test the hoses. You create a vacuum pumping air out while the other side is plugged and watch the gauge if you keep or loose the vacuum. you can also buy (instead of a tool) 20 bucks worth of vacuumhoses and replace the old ones.20 bucks will not be enough to replace them all. Keep in mind you cannot just use any hose for the stronger-vacuum ones.... good luck! |
Lo-Fi Version | Time is now: 12th May 2024 - 04:11 PM |
