Need help with my 74 914 |
Ncchany |
Dec 4 2016, 11:28 AM
Newbie Group: Members Posts: 36 Joined: 1-October 16 From: New york Member No.: 20,456 Region Association: None |
Today i tried to start the car i bought a couple of months. I changed the oil and bought a new battery. Any ideas? Here is a video of the entire car. All it did when i turned the key was just make a click
https://youtu.be/q_WpOO3RJas I changed it to youtube |
TheCabinetmaker |
Dec 4 2016, 12:04 PM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Thank you. That's better. The click is the solenoid on the starter. Use a screwdriver to short the large red wire on the starter to the yellow wire on the solenoid. Make sure the car is in neutral and parking brake on (or wheels chocked). If it cranks, your problem is most likely the electrical portion of the ignition switch.
Ncchany |
Dec 4 2016, 12:11 PM
Thank you. That's better. The click is the solenoid on the starter. Use a screwdriver to short the large red wire on the starter to the yellow wire on the solenoid. Make sure the car is in neutral and parking brake on (or wheels chocked). If it cranks, your problem is most likely the electrical portion of the ignition switch. The rear brake light was on. However the stick for the gear moves freely and doesnt even allow it to gonin gear at all sonidk if its in gear. These cars are different then anything ive ever worked on |
Lo-Fi Version | Time is now: 23rd May 2024 - 06:53 AM |
