Ncchany
Dec 4 2016, 11:28 AM
Today i tried to start the car i bought a couple of months. I changed the oil and bought a new battery. Any ideas? Here is a video of the entire car. All it did when i turned the key was just make a click
https://youtu.be/q_WpOO3RJasI changed it to youtube
TheCabinetmaker
Dec 4 2016, 11:35 AM
Well that sucked! I clicked your link and the ads took over and locked my phone. It said the video is corrupted. Grrrrr!
Don't click that link.
Edit: link fixed.
Ncchany
Dec 4 2016, 11:47 AM
Sorry avout that i changed it over to youtube now... check it out
Ncchany
Dec 4 2016, 12:02 PM
QUOTE(The Cabinetmaker @ Dec 4 2016, 12:35 PM)
I removed that video and uplod it through utube
TheCabinetmaker
Dec 4 2016, 12:04 PM
Thank you. That's better. The click is the solenoid on the starter. Use a screwdriver to short the large red wire on the starter to the yellow wire on the solenoid. Make sure the car is in neutral and parking brake on (or wheels chocked). If it cranks, your problem is most likely the electrical portion of the ignition switch.
Ncchany
Dec 4 2016, 12:11 PM
QUOTE(The Cabinetmaker @ Dec 4 2016, 01:04 PM)
The rear brake light was on. However the stick for the gear moves freely and doesnt even allow it to gonin gear at all sonidk if its in gear. These cars are different then anything ive ever worked on
Ncchany
Dec 4 2016, 12:12 PM
I assume its in nuetral because it rolls back and forth? Also my brakes are frozen
rhodyguy
Dec 4 2016, 12:41 PM
Did you buy a Haynes manual yet? You might consider using a shop vac on the enigine compartment. Easier to navigate without all of the debris in the way.
TheCabinetmaker
Dec 4 2016, 12:43 PM
What the heck? How does it roll with the brakes frozen?
Ou?
Ncchany
Dec 4 2016, 01:06 PM
QUOTE(The Cabinetmaker @ Dec 4 2016, 01:43 PM)
Ou?
Hand brake is frozen doesnt move upnorndown. Pumping the brake does nothing
Ncchany
Dec 4 2016, 11:41 PM
QUOTE(rhodyguy @ Dec 4 2016, 01:41 PM)
Yea i have the book on a cd i just need to print it. And yea ina buy a vdry wet vac from harborfreight
injunmort
Dec 5 2016, 08:51 AM
how long has the car been sitting? does the engine turn over by hand? where in ny are you? from the video it sounds like the starter gear is kicking out but the engine is not turning. remove spark plugs, jack up one of the rear wheels and turn it with the car in gear. make sure the motor is not stuck.
Ncchany
Dec 5 2016, 10:43 AM
QUOTE(injunmort @ Dec 5 2016, 09:51 AM)
The car is in old bridge nj. Probably a little over an hour from sugarlof. If your down i can give you a ride back and forth on the weekend if your free. Im really use to these cars i have no idea what to turn. I have a spitfire and did most the work myself this is definitely more of a challenge
injunmort
Dec 5 2016, 05:46 PM
i can come down over the weekend and help you get started to making progress. send me a PM and we'll hook up.
TheCabinetmaker
Dec 5 2016, 06:31 PM
Post#6. These cars are different then anything ive ever worked on
Post#13 Im really use to these cars
So which is it?
76-914
Dec 5 2016, 06:48 PM
QUOTE(The Cabinetmaker @ Dec 5 2016, 04:31 PM)
So which is it?
I think he meant
not used to, Curt.
Ncchany
Dec 5 2016, 10:19 PM
QUOTE(The Cabinetmaker @ Dec 5 2016, 07:31 PM)
So which is it?
Typo . Not used to
cgnj
Dec 6 2016, 04:29 AM
Doesn't sound good. Pull the plugs, marvel mystery oil and see if the motor turns.
Hope you have jackstands.
Ncchany
Dec 6 2016, 02:10 PM
QUOTE(cgnj @ Dec 6 2016, 05:29 AM)
Yes the car is on jackstands. Ima clean the engine out then ill pull the plusp
green914
Dec 6 2016, 03:08 PM
Looks like you have a lot of fun waiting for you
Ncchany
Dec 6 2016, 05:57 PM
QUOTE(green914 @ Dec 6 2016, 04:08 PM)
Thanks i just want to get this thing running. Everything else will come with tome
krazykonrad
Dec 6 2016, 07:38 PM
We'll get you through this.
Konrad
Ncchany
Dec 6 2016, 11:22 PM
QUOTE(krazykonrad @ Dec 6 2016, 08:38 PM)
Konrad
I hope so thankfully this forum is filled with helpful ppl some which are coming tomhelp me get started. One day when im a pro i will do the same
Dave_Darling
Dec 7 2016, 01:56 PM
You don't need to be a pro to help out. Just be willing to help!
I helped my grandfather restore a B-17 once. My help? Holding a big handful of screws and handing him one each time he stuck his hand out.
--DD
