Removing section of the wiring loom |
JFG |
Dec 4 2016, 01:43 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
As I'm fitting twin 40 IDF's I have no need for the missing fi system including the extra wiring that would go to the relay board in the engine bay.
Is there a straightforward way to remove the no longer needed section of loom, either by rerouting bits that may be needed elsewhere or simply removing altogether? 1974 2.0 |
JFG |
Dec 4 2016, 05:03 PM
There was no relay board in the engine compartment when i bought the car. All i have is the wiring on the main loom with the multi pin plug on the end.
SirAndy |
Dec 4 2016, 06:18 PM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
There was no relay board in the engine compartment when i bought the car. All i have is the wiring on the main loom with the multi pin plug on the end. You'll need the *relay* board. Also, voltage regulator anyone? http://www.914world.com/specs/SirAndyCarbFuelPumpRelay.php |
Lo-Fi Version | Time is now: 10th May 2024 - 11:04 PM |
