Removing section of the wiring loom |
JFG |
Dec 4 2016, 01:43 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
As I'm fitting twin 40 IDF's I have no need for the missing fi system including the extra wiring that would go to the relay board in the engine bay.
Is there a straightforward way to remove the no longer needed section of loom, either by rerouting bits that may be needed elsewhere or simply removing altogether? 1974 2.0 |
JFG |
Dec 4 2016, 05:03 PM
There was no relay board in the engine compartment when i bought the car. All i have is the wiring on the main loom with the multi pin plug on the end.
porschetub |
Dec 5 2016, 01:06 AM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
There was no relay board in the engine compartment when i bought the car. All i have is the wiring on the main loom with the multi pin plug on the end. Wow that changes the game.....best to research before then we would know (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) ,so much info out there and on here,Bruces offer is very generous go for it. Best to research your carb install as theres many wrong ways and a few right ways,if not you will be disappointed ,good luck. |
Lo-Fi Version | Time is now: 11th May 2024 - 03:35 PM |
