Stock front torsion bar size 17.9mm?, do I have the wrong ones,how can I check? |
porschetub |
Dec 4 2016, 01:48 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Car has very firm ride in the front,I have Bilstein inserts in Boge struts but the ride is really bone jarring to the point that I have disconnected the swaybar to try and soften it up a little which it did.
Previous to unhooking the swaybar I couldn't even bounce the front of the car with my own weight,needless to say the car isn't that nice to drive (IMG:style_emoticons/default/sad.gif) . Is there an easy way to check the size,are they marked on the ends? I strongly suspect they are too larger diameter or not setup right (indexing ?) maybe,any helpful suggestions guys,thanks in advance. PS front is only lowered a small amount. |
Tom_T |
Dec 4 2016, 09:42 PM
IIRC they were originally stock only 16 mm front & 15 mm rear on both the /4 & -6, or I may have that Bass-ackwards.
FYI - My `73 were stock, Boge struts with classic Koni Sport inserts, lowered an inch & all front bushings replaced back in 1980-83 resto/rebuild, & it rode fine without any harshness nor bump steer. So maybe the bushings noted above & proprer smaller sized sway bar with smooth yours out? (IMG:style_emoticons/default/confused24.gif) Here are the back-in-the-day Road & Track spec for my 73 2.0, but it doesn't list the sway/anti-roll bar sizes.... Good Luck! (IMG:style_emoticons/default/beerchug.gif) /////// |
bdstone914 |
Dec 4 2016, 10:03 PM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Stock is 15mm stamped on one end and rear is 16mm.
Dave_Darling |
Dec 5 2016, 02:48 PM
Stock is 15mm stamped on one end and rear is 16mm. Not the torsion bars! Remember that the 914 doesn't have rear torsion bars, it uses coil springs on the rear! The fronts would be 17.9mm, as mentioned. The sway bars are the dimensions stated above; 15mm diameter for the front bar and 16mm diameter for the rear bar. --DD |
Lo-Fi Version | Time is now: 19th May 2024 - 09:40 AM |
