Stock front torsion bar size 17.9mm?, do I have the wrong ones,how can I check? |
porschetub |
Dec 4 2016, 01:48 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Car has very firm ride in the front,I have Bilstein inserts in Boge struts but the ride is really bone jarring to the point that I have disconnected the swaybar to try and soften it up a little which it did.
Previous to unhooking the swaybar I couldn't even bounce the front of the car with my own weight,needless to say the car isn't that nice to drive (IMG:style_emoticons/default/sad.gif) . Is there an easy way to check the size,are they marked on the ends? I strongly suspect they are too larger diameter or not setup right (indexing ?) maybe,any helpful suggestions guys,thanks in advance. PS front is only lowered a small amount. |
rhodyguy |
Dec 6 2016, 01:06 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Not the compression of strut itself but the control arm thru its range of motion. Other than stock rubber bushings on the control arm?
Lo-Fi Version | Time is now: 19th May 2024 - 07:51 AM |
