1.7 Engine Build Questions, Need advice on what I should know |
Matty900 |
Dec 5 2016, 01:29 AM
Senior Member Group: Members Posts: 1,269 Joined: 21-February 15 From: Oregon Member No.: 18,454 Region Association: Pacific Northwest |
My 72 barn find ( http://www.914world.com/bbs2/index.php?sho...=275587&hl= ) is now starting to get a lot of work done so I can hopefully make it to lots of rallies next year. The car Has 50K original miles on a 1.7 that had some work on it previously making it a 1911 with Dlortos on it.
The engine is now torn down for rebuild with a little more power. I would like it to look as stock as possible but would like it to be a sleeper. I am considering 2.0 LTR FI and having everything else built. I am looking for suggestions on what you would do to the engine and why. Thanks for the help Attached thumbnail(s) Attached image(s) |
McMark |
Dec 5 2016, 08:23 PM
71mm stroke is stock 2.0.
71mm x 94mm is 1971, which is the stock 2.0 size. 71mm x 96mm is 2056. Stock 71mm crank and rods are fine for most builds, no need for fancy upgraded components. If I were you, I'd look at a 1911, with a focus on lightening. Order of 'upgrades' by cost/benefit (in my opinion) Core 1911 (what you've got now, your starting point) Lightened flywheel. New 96mm pistons and cylinders. 2.0 heads. Valves/springs/retainers/pushrods for high RPM (lighter/stiffer). Lightened connecting rods. Lightened pistons. |
Matty900 |
Dec 6 2016, 02:00 PM
71mm stroke is stock 2.0. 71mm x 94mm is 1971, which is the stock 2.0 size. 71mm x 96mm is 2056. Stock 71mm crank and rods are fine for most builds, no need for fancy upgraded components. If I were you, I'd look at a 1911, with a focus on lightening. Order of 'upgrades' by cost/benefit (in my opinion) Core 1911 (what you've got now, your starting point) Lightened flywheel. New 96mm pistons and cylinders. 2.0 heads. Valves/springs/retainers/pushrods for high RPM (lighter/stiffer). Lightened connecting rods. Lightened pistons. What about the cam? I know the PO had already done some work on it. What do I want it to be? |
Lo-Fi Version | Time is now: 11th May 2024 - 03:18 PM |
