Euromeisters, 16x7 on all four under stock fenders |
mmascari |
Dec 7 2016, 11:18 PM
Member Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
Anyone running Euromeisters 16x7 on all four corners? Curious if they fit under stock fenders. I don't think they make a 16x6.
Keith914 |
Dec 7 2016, 11:48 PM
Member Group: Members Posts: 248 Joined: 29-April 16 From: Laguna Beach, California 92651 Member No.: 19,948 Region Association: Southern California |
Yes. Easy fit in front. I had to "role the rear fender edges in with a baseball bat", rolling the bat back and forth between the tire and fender, starting with th car jacked up for enough clearance etc. Tire size choice is an issue, I selected 205x45x16 tires. Happy to discuss further with you, -- PM me.
mmascari |
Dec 8 2016, 12:01 AM
Thanks Keith. If you have a photo post it so I can see how it looks. I have Boxster wheels now which are 16x7 in back, however, 16x6 in front. I really like the Fuchs style better though.
Mark Henry |
Dec 8 2016, 08:53 AM
What ET are they and a link?
Posted this a couple days ago. http://www.914world.com/bbs2/index.php?sho...p;#entry2430954 |
Keith914 |
Dec 8 2016, 09:43 AM
Here you are:
Mueller |
Dec 8 2016, 11:47 AM
What ET are they and a link? Posted this a couple days ago. http://www.914world.com/bbs2/index.php?sho...p;#entry2430954 ET 40 from a quick search for the rears that he is currently running. OP, are you using spacers? Basically the new wheels will stick out towards the fender lip 17mm more that your current setup. I like those Boxster wheels, they look pretty good on a 914. |
jim_hoyland |
Dec 8 2016, 12:28 PM
Get that VIN ? Group: Members Posts: 9,291 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Yes. Easy fit in front. I had to "role the rear fender edges in with a baseball bat", rolling the bat back and forth between the tire and fender, starting with th car jacked up for enough clearance etc. Tire size choice is an issue, I selected 205x45x16 tires. Happy to discuss further with you, -- PM me. Would 195's require fender rolling as well ? |
mmascari |
Dec 8 2016, 03:58 PM
Thanks for the pics, my car is also silver and they look awesome.
Keith914 |
Dec 8 2016, 04:00 PM
My tire side walls extend 1/8" outside the rim edge, running 205x45x16's.
RichPugh |
Dec 8 2016, 04:21 PM
Member Group: Members Posts: 124 Joined: 28-October 14 From: Baltimore, MD Member No.: 18,068 Region Association: MidAtlantic Region |
The Euromeister 16x7's are 23.3et (not 40). I plan on running them too... Probably with a slightly smaller tire but I would LOVE to see if the 951 23.3et 8" fits the rear with a 205/40 or a 215/35... with mild fender modification.
http://www.automotion.com/euromeister-allo...or-porsche.html |
Mueller |
Dec 8 2016, 04:51 PM
The Euromeister 16x7's are 23.3et (not 40). I plan on running them too... Probably with a slightly smaller tire but I would LOVE to see if the 23.3et 8" fits the rear with a 205/40 or a 215/35... with mild fender modification. http://www.automotion.com/euromeister-allo...or-porsche.html 40mm offset is his current Boxster wheels. Even with the 7" 23mm offset you will have to modify the fender lip, an 8" 23mm offset wheel will require mods for sure, I guess it depends on your definition of "mild" See pic below, my old car....8" 23mm offset rims Fender cut and welded. (IMG:http://www.914world.com/bbs2/uploads_offsite/members.rennlist.com-87-1481237468.1.jpg) |
mmascari |
Dec 8 2016, 05:01 PM
What ET are they and a link? Posted this a couple days ago. http://www.914world.com/bbs2/index.php?sho...p;#entry2430954 ET 40 from a quick search for the rears that he is currently running. OP, are you using spacers? Basically the new wheels will stick out towards the fender lip 17mm more that your current setup. I like those Boxster wheels, they look pretty good on a 914. No spacers. So the offset of the Euromeisters is different than the stock Boxster wheels and therefore stick out more toward the fender an additional 17mm? That is not good and makes sense why some require rolling the fender lip. |
RichPugh |
Dec 8 2016, 05:15 PM
QUOTE 40mm offset is his current Boxster wheels. Even with the 7" 23mm offset you will have to modify the fender lip, an 8" 23mm offset wheel will require mods for sure, I guess it depends on your definition of "mild" See pic below, my old car....8" 23mm offset rims Fender cut and welded. oops... I missed the Boxster wheel bit there. Sorry. What tires are you running on those 23.3et 8's? I planned to run a 195/45 on all 4 corners on 7's. |
RichPugh |
Dec 8 2016, 05:17 PM
QUOTE So the offset of the Euromeisters is different than the stock Boxster wheels and therefore stick out more toward the fender an additional 17mm? That is not good and makes sense why some require rolling the fender lip. No, the Boxster ones are 40et... that would push them inwards an additional 17mm (16.7) than the 23.3et ones if theyre the same width. |
Mark Henry |
Dec 8 2016, 05:33 PM
What ET are they and a link? Posted this a couple days ago. http://www.914world.com/bbs2/index.php?sho...p;#entry2430954 ET 40 from a quick search for the rears that he is currently running. OP, are you using spacers? Basically the new wheels will stick out towards the fender lip 17mm more that your current setup. I like those Boxster wheels, they look pretty good on a 914. No spacers. So the offset of the Euromeisters is different than the stock Boxster wheels and therefore stick out more toward the fender an additional 17mm? That is not good and makes sense why some require rolling the fender lip. Why I was asking about the ET (back spacing) on the Euromiesters, ET23 is going to give you issues. Also I'm not fond of the look of the smaller than stock OD tire, to me it just looks odd, not to mention it throws off your speedo and gear ratios. The ET 40 will have less issues and using spacers a bit more wiggle room. I looked up Euromiesters on a few sites and didn't see a 16X7 ET40, only ET23. cip1(dot)com has the 17X7 ET40, but I have no idea on quality, I have heard (3rd hand) they are heavy. Most likely they are made in China. Using the calculator I posted, if you plug in 165/80-15 ET40 5.5 inch rim and 205/50-17 ET40 7 inch rim, you get an almost exact same size wheel as stock with 3/4" wider on each side. To get the same with 16X7" you would need a ET40 and 205/55-16 tire. The big caveat is no two brands of tire are dimensionally the same. |
mmascari |
Dec 8 2016, 06:23 PM
What ET are they and a link? Posted this a couple days ago. http://www.914world.com/bbs2/index.php?sho...p;#entry2430954 ET 40 from a quick search for the rears that he is currently running. OP, are you using spacers? Basically the new wheels will stick out towards the fender lip 17mm more that your current setup. I like those Boxster wheels, they look pretty good on a 914. No spacers. So the offset of the Euromeisters is different than the stock Boxster wheels and therefore stick out more toward the fender an additional 17mm? That is not good and makes sense why some require rolling the fender lip. Why I was asking about the ET (back spacing) on the Euromiesters, ET23 is going to give you issues. Also I'm not fond of the look of the smaller than stock OD tire, to me it just looks odd, not to mention it throws off your speedo and gear ratios. The ET 40 will have less issues and using spacers a bit more wiggle room. I looked up Euromiesters on a few sites and didn't see a 16X7 ET40, only ET23. cip1(dot)com has the 17X7 ET40, but I have no idea on quality, I have heard (3rd hand) they are heavy. Most likely they are made in China. Using the calculator I posted, if you plug in 165/80-15 ET40 5.5 inch rim and 205/50-17 ET40 7 inch rim, you get an almost exact same size wheel as stock with 3/4" wider on each side. To get the same with 16X7" you would need a ET40 and 205/55-16 tire. The big caveat is no two brands of tire are dimensionally the same. What about real Fuchs? Are they ET40? For example a set of 16x7 from a 911sc? |
sixnotfour |
Dec 8 2016, 06:28 PM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
the only factory Fuchsis a 15 inch and was the 911R wheel..close to 40mm.. I have these fake fuchs and fit great..40mm http://www2.cip1.com/ProductDetails.asp?Pr...Code=C13%2D9739 |
RichPugh |
Dec 8 2016, 06:43 PM
RichPugh |
Dec 8 2016, 06:48 PM
QUOTE What about real Fuchs? Are they ET40? For example a set of 16x7 from a 911sc? Real Fuchs in 16x7 are 23.3et. Here's a Chart for the real Fuchs sizes, part numbers and offsets. (IMG:http://www.914world.com/bbs2/uploads/post-1623-1481069649.jpg) There is also this... members.rennlist.com/911pcars/WheelWts.html |
TravisNeff |
Dec 8 2016, 07:03 PM
I agree that tire selection is critical. These are 205x55x16 on a 7" rim, notice how wide they stick out past the rim for this particular tire brand. I had to do obscene things to the rear fenders to get it to fit, and I'll have to have a body shop fixed what I fixed!
If I had to do it over I would have tried the 195x55x16 RE71R tire. Right in between overall height from a 50 to 55 series 205 tire, and the section width is little bit less. Live and learn. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 15th May 2024 - 05:34 AM |
