Best Paint for Roof?, Anybody paint theirs? |
oakdalecurtis |
Dec 8 2016, 08:31 AM
Oakdalecurtis Group: Members Posts: 1,325 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
If I were to spray paint the outside of the roof panel, anyone have experience with what brand and "shade" of black (satin, gloss, flat etc.) might most match the original look, or any other comments on this process?
Txbentleyboy |
Dec 8 2016, 10:28 AM
Member Group: Members Posts: 73 Joined: 15-October 16 From: Davidson County, NC, USA Member No.: 20,498 Region Association: MidAtlantic Region |
I'd like to know that too.
StratPlayer |
Dec 8 2016, 11:15 AM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
I didn't use paint,,, I use Forever Black
There is a thread on here about that. |
oakdalecurtis |
Dec 8 2016, 11:33 AM
ericoneal |
Dec 8 2016, 11:34 AM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I plasti-dipped mine. Turned out ok.
iankarr |
Dec 8 2016, 11:37 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Search is your friend (IMG:style_emoticons/default/wink.gif).
http://m.914world.com/bbs2/index.php?showtopic=298337 The site search isn't as fast as just googling "914world" and whatever you're looking to find. |
StratPlayer |
Dec 8 2016, 11:59 AM
Eric_Shea |
Dec 8 2016, 12:19 PM
McMark here does the finest roof restorations I've ever seen. Basically spot on perfect.
If you just want to re-spray yours, use a semi-gloss "automotive" paint vs. rattle-can. That said, most automotive paint stores will mix you what you want in a 2K can with hardener built in. You turn the key at the bottom of the can and it releases the hardener into the paint. You basically have 24 hours to use it. They cost around $15.00 - $20.00 but well worth it. You can show them the sheen you want and they can customize the glossing agent as well. |
porschetub |
Dec 8 2016, 12:31 PM
Got a spare roof with my car was thinking I might paint it body colour for something different.
Anyone got any pics with this done? |
Tom_T |
Dec 8 2016, 01:01 PM
Curtis,
Most folks refinish the tops too shiny for the original look, & i disagree with semi-gloss as the correct finish. If you want to keep it the original factory look, then semi-gloss is too shiny, but satin or semi-flat is close to original. If you're just top coating the original pebble finish, then prep it well & shoot a good quality satin/semi-flat. However, if it has damage/peeling to repair or requiring stripping, or you want to strip to the bare fiberglass, then you'll need to recreate the texture with Wurth Underbody Schutz, & they make a Satin & Flat/Semi-Flat black paint as well (TCGarage.com in San Marcos carries Wurth products). There are some topics in the O&H Forum on how to get the original texure & finish, & the one by Pat Garvey is one of the best, but you'll have to google for it (I've lost my bookmark), here: http://www.914world.com/bbs2/index.php?showforum=44 BTW - the F & R valances & L & R Rockers are the same finsih, so you could do them all with the roof panel at the same time. Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Frankvw |
Dec 8 2016, 02:08 PM
working on my first 914 ! Group: Members Posts: 651 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
Localboy808 |
Dec 8 2016, 02:13 PM
Member Group: Members Posts: 185 Joined: 17-July 16 From: Palmdale, Ca Member No.: 20,194 Region Association: None |
If I were to spray paint the outside of the roof panel, anyone have experience with what brand and "shade" of black (satin, gloss, flat etc.) might most match the original look, or any other comments on this process? I did this with Wrinkle paint by VHT that you can get at Auto Zone. I like the way it came out. Looks pretty close to the original texture. And was affordable. |
PlantMan |
Dec 8 2016, 03:13 PM
Member Group: Members Posts: 435 Joined: 14-May 14 From: Mission Viejo Member No.: 17,352 Region Association: Southern California |
I used to use a similar product by Turtle Wax 20+ years ago that was excellent on the top. Even if you have a few minor imperfections it would hide them and give you a great black finish. It was like shoe polish with a UV protectant. Apply and hit it with a shoe brush after and it would clean-up nicely. I would like to try this out on mine and see how it goes. Appears to be similar to the Turtle Wax stuff which was for 'soft tops'. |
oakdalecurtis |
Dec 8 2016, 04:57 PM
McMark here does the finest roof restorations I've ever seen. Basically spot on perfect. If you just want to re-spray yours, use a semi-gloss "automotive" paint vs. rattle-can. That said, most automotive paint stores will mix you what you want in a 2K can with hardener built in. You turn the key at the bottom of the can and it releases the hardener into the paint. You basically have 24 hours to use it. They cost around $15.00 - $20.00 but well worth it. You can show them the sheen you want and they can customize the glossing agent as well. Eric, after it's mixed, you apply it with a brush or roller?? |
oakdalecurtis |
Dec 8 2016, 04:59 PM
Curtis, Most folks refinish the tops too shiny for the original look, & i disagree with semi-gloss as the correct finish. If you want to keep it the original factory look, then semi-gloss is too shiny, but satin or semi-flat is close to original. If you're just top coating the original pebble finish, then prep it well & shoot a good quality satin/semi-flat. However, if it has damage/peeling to repair or requiring stripping, or you want to strip to the bare fiberglass, then you'll need to recreate the texture with Wurth Underbody Schutz, & they make a Satin & Flat/Semi-Flat black paint as well (TCGarage.com in San Marcos carries Wurth products). There are some topics in the O&H Forum on how to get the original texure & finish, & the one by Pat Garvey is one of the best, but you'll have to google for it (I've lost my bookmark), here: http://www.914world.com/bbs2/index.php?showforum=44 BTW - the F & R valances & L & R Rockers are the same finsih, so you could do them all with the roof panel at the same time. Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// Thanks Tom, roof is in pretty good shape, only want to paint it. Appreciate your advice, as usual! |
Lo-Fi Version | Time is now: 16th May 2024 - 04:06 AM |
