Brake pads for Alfa 3" front calipers |
Dec 12 2016, 08:53 AM
Anybody have a part number?
I want to order from one of my suppliers. Thanks. |
rhodyguy |
Dec 12 2016, 09:00 AM
Check with Shea.
Montreal914 |
Dec 12 2016, 11:21 PM
Senior Member Group: Members Posts: 1,559 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
If I recall, same as S aluminum calipers.
Can't find my receipt (IMG:style_emoticons/default/headbang.gif) |
Montreal914 |
Dec 12 2016, 11:28 PM
Found it...
What I bought from PMB was Porterfield AP109 R4-S. |
ConeDodger |
Dec 12 2016, 11:54 PM
Apex killer! Group: Members Posts: 23,587 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Found it... What I bought from PMB was Porterfield AP109 R4-S. Me too... (IMG:style_emoticons/default/agree.gif) |
bdstone914 |
Dec 13 2016, 09:04 AM
Anybody have a part number? I want to order from one of my suppliers. Thanks. As I recall they were stock on 1975-1976 Alfa Spiders. The next year car had the same caliper in steel. I was the one that discovered they work on 911 suspension when I found to Alfa's in a pick a part yard and bought the calipers. Eric sucessfully bought up all the cores out there and pissed off the Alfa guys. Seems that Alfa abandoned the aluminum caliper for the same alledged flexing problem the S calipers have. Never bought into how big the problem is if they stop the car fast. Bruce |
Mark Henry |
Dec 13 2016, 09:11 AM
Anybody have a part number? I want to order from one of my suppliers. Thanks. As I recall they were stock on 1975-1976 Alfa Spiders. The next year car had the same caliper in steel. I was the one that discovered they work on 911 suspension when I found to Alfa's in a pick a part yard and bought the calipers. Eric sucessfully bought up all the cores out there and pissed off the Alfa guys. Seems that Alfa abandoned the aluminum caliper for the same alledged flexing problem the S calipers have. Never bought into how big the problem is if they stop the car fast. Bruce I thought they were on the mid 80's Milano and GTV-6? IIRC that's what mine are off of. In a pinch you could use '71- '72 VW bus pads by minor grinding some mounting bolt clearance on the inboard pad. |
Dec 13 2016, 09:37 AM
I got it. Thanks
ConeDodger |
Dec 13 2016, 10:07 AM
Anybody have a part number? I want to order from one of my suppliers. Thanks. As I recall they were stock on 1975-1976 Alfa Spiders. The next year car had the same caliper in steel. I was the one that discovered they work on 911 suspension when I found to Alfa's in a pick a part yard and bought the calipers. Eric sucessfully bought up all the cores out there and pissed off the Alfa guys. Seems that Alfa abandoned the aluminum caliper for the same alledged flexing problem the S calipers have. Never bought into how big the problem is if they stop the car fast. Bruce I thought they were on the mid 80's Milano and GTV-6? IIRC that's what mine are off of. In a pinch you could use '71- '72 VW bus pads by minor grinding some mounting bolt clearance on the inboard pad. Mine are from a GTV-6 |
Eric_Shea |
Dec 13 2016, 11:56 AM
109's same as 320i stuff.
Lo-Fi Version | Time is now: 16th May 2024 - 09:12 AM |
