rust on prospective purchase, 914 bottom of pan rust? |
Will Hesch |
Dec 12 2016, 04:53 PM
Newbie Group: Members Posts: 18 Joined: 8-December 16 From: Atascadero, California Member No.: 20,655 Region Association: Central California |
Hi, I'm a newbie but a knowledgeable car nut. I'm looking at a '73 2.0 in the Great Lakes area. The seller claims it's "rust free" but the battery tray is very rusty and the pan/underside shows rust as well.
In particular, there are two areas on either side of the trans/motor mount that concerns me, I've circled the two (apparent?) holes in the second photo. I don't know if those are factory or rust installed, maybe you guys could help me? Thank you in advance! Will in California 805-550-7865 |
boxsterfan |
Dec 12 2016, 05:06 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Need to get a look behind the ECU there in the engine bay to see the hell hole aea under the battery tray. Also, #1 thing to see is underneath the rocker panels on both sides. Need to take the rocker panels off to see them in their full glory (or not so glory).
jmitro |
Dec 12 2016, 05:15 PM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
those holes are stamped as part of the factory lift points, so no problem
Battery tray is relatively clean, not too bad really. The car looks pretty good in the two photos that you have shown. |
Will Hesch |
Dec 12 2016, 05:25 PM
those holes are stamped as part of the factory lift points, so no problem Battery tray is relatively clean, not too bad really. The car looks pretty good in the two photos that you have shown. Jmitro, thanks, I agree that in comparison to many 914 battery trays, this one's not completely toast but it's a far cry from "rust free" as advertised. Boxter, I'm in Cali so I can't pull the rocker covers. I'm waiting on photos of the Hell-hole, told the seller he needs to pull the hoses out of the way so I can see it. From the top-side, the car looks immaculate but it's a long trip from California and I really don't want surprises. Will |
Ferg |
Dec 12 2016, 05:28 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
Personally I would not make the trip until I saw clear pics of under the rocker panels. Seller should be able to accommodate it's not hard.
rhodyguy |
Dec 12 2016, 05:46 PM
see if you can find a knowledgeable member that's local to the car have a close look at it. even if you pay them for their time it's the best money you'll spend. it might save you thousands and years.
porschetub |
Dec 12 2016, 05:54 PM
That's not rusty trust me but do check under the battery tray ,that's the important area. Hard to tell from the other pic,try to add one a bit closer ,nice oil free engine go ok? |
boxsterfan |
Dec 12 2016, 06:21 PM
I second the "find a local 914World" member to check it out for you. The other thing about pictures is that less-then-scrupulous sellers will send you pictures....but from 10-15 years ago. Ask me how I know....I once thought I owned a fabulous "no rust" 1970 Adriatic Blue 1.7L until I received the car and the seller was nowhere to be found.
rhodyguy |
Dec 12 2016, 06:32 PM
Agreed the floor looks nice. How cheaply can you fly to the car? Part of the investment.
JimN73 |
Dec 12 2016, 06:41 PM
Senior Member Group: Members Posts: 535 Joined: 6-October 07 From: Gig Harbor Member No.: 8,192 Region Association: Pacific Northwest |
How much of a project are you looking for? And how much trust will you give the current owner?
There are usually lots of California/west coast cars needing some, a little or a lot of work. And you can fly the whole coast in a morning and get a firsthand look. |
jmill |
Dec 12 2016, 08:07 PM
Where in the Great Lakes area? It's a big lake that covers several states. I'm in Racine WI, just south of Milwaukee and 45 min North of Chicago. If close I'll look at it for you.
I bought a car from AZ and shipped it. Most out here are toast. |
72914wrx |
Dec 12 2016, 08:35 PM
Member Group: Members Posts: 86 Joined: 5-January 15 From: Fresno Member No.: 18,298 Region Association: None |
Why don't you buy a car from California where are cars are slow to rust . Best advise find a car with no rust because it can get expensive quick !
Will Hesch |
Dec 12 2016, 09:10 PM
The car's in Menasha, Wisconson, if any of you are near there, I would gladly pay you to check the car for me.
You can call me anytime at 805-550-7865 or e-mail me at will@centralcoastbassfishing.com Thanks, Will |
jmill |
Dec 13 2016, 12:50 PM
That battery tray concerns me. Where's the hole and the dropped floor in the center?The hell hole really needs to be looked at. Can he pop off the passenger rocker and snap a picture of the long around the jack point?
dlee6204 |
Dec 13 2016, 01:10 PM
That battery tray concerns me. Where's the hole and the dropped floor in the center?The hell hole really needs to be looked at. Can he pop off the passenger rocker and snap a picture of the long around the jack point? (IMG:style_emoticons/default/agree.gif) Yeah, the battery tray has been messed with/repaired. |
Dec 13 2016, 01:11 PM
Resident German Group: Admin Posts: 41,638 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
That battery tray concerns me. Where's the hole and the dropped floor in the center? The tray was probably replaced/patched when the car was repainted ... (IMG:style_emoticons/default/shades.gif) |
orthobiz |
Dec 15 2016, 04:10 AM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
This was my guaranteed rust free car.
Paul Attached thumbnail(s) |
orthobiz |
Dec 15 2016, 04:12 AM
All better now! California car, by the way.
Paul Attached image(s) |
Lo-Fi Version | Time is now: 16th May 2024 - 08:09 AM |
