QQ are you able to use the 914 cross member with 911 control arms?, this one is simple i hope |
tazz9924 |
Dec 13 2016, 07:19 PM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
working on peicing together a 911 front suspension and i was curious if the crossmembers are the same (other than the aluminum bit) and will alow for the use of 911 control arms on a 914 cross member
Chris914n6 |
Dec 13 2016, 07:32 PM
Jackstands are my life. Group: Members Posts: 3,319 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Yes, but the 911 & 914 covers mounts different.
jmill |
Dec 13 2016, 08:44 PM
That's what I'm running. Works just fine and keeps the weight low and up front where the 914 needs it.
raynekat |
Dec 13 2016, 09:06 PM
Advanced Member Group: Members Posts: 2,158 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
I'm going the opposite and it works.
Putting the 914-4 A-arms onto the 911 aluminum crossmember with 911 struts. It's all pretty interchangeable. Excepting the cover panel that bolts on from below as previously pointed out. |
Steve |
Dec 13 2016, 10:13 PM
914 Guru Group: Members Posts: 5,585 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Curious what did you guys do to the cover to make it fit?
Lo-Fi Version | Time is now: 15th May 2024 - 11:39 PM |
