tazz9924
Dec 13 2016, 07:19 PM
working on peicing together a 911 front suspension and i was curious if the crossmembers are the same (other than the aluminum bit) and will alow for the use of 911 control arms on a 914 cross member
Chris914n6
Dec 13 2016, 07:32 PM
Yes, but the 911 & 914 covers mounts different.
jmill
Dec 13 2016, 08:44 PM
That's what I'm running. Works just fine and keeps the weight low and up front where the 914 needs it.
raynekat
Dec 13 2016, 09:06 PM
I'm going the opposite and it works.
Putting the 914-4 A-arms onto the 911 aluminum crossmember with 911 struts.
It's all pretty interchangeable.
Excepting the cover panel that bolts on from below as previously pointed out.
Steve
Dec 13 2016, 10:13 PM
Curious what did you guys do to the cover to make it fit?
