WTB...for daughter's 1.8....wants more loving, muffler for 74 1.8, and wiper switch lever, and shifter sleeve |
porbmw |
Dec 14 2016, 10:33 PM
Senior Member Group: Members Posts: 811 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None |
YUP, by the time her car is done, seems every piece will have been repaired or replaced...
And in the 6 years of getting/keeping hers going...mine sits awaiting assembly (IMG:style_emoticons/default/dry.gif) Anyway, 'nuf whining Am in the hunt for: a)muffler for 1.8. I believe they are unique to the 1.8...and ASSUME that they are the same for both years? b)shifter sleeve on the rearof the shifter rod...it MAY be 91442424102, if that helps c)wiper switch/lever that mounts on column.... Thanks Paul |
bdstone914 |
Dec 15 2016, 09:01 AM
bdstone914 Group: Members Posts: 4,521 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
74 and 75 1.8 use a different muffler due to the type of heat exchangers. The 74 is a one year only muffler with larger pipes than the 1.7. The outlet tip bolts to the end of the muffler unlike the 1.7 which has a couple of configs. I have one muffler and will check to see what it is.
And I have the cup for the end of the rear side shift rod. Bruce |
porbmw |
Dec 16 2016, 08:57 AM
74 and 75 1.8 use a different muffler due to the type of heat exchangers. The 74 is a one year only muffler with larger pipes than the 1.7. The outlet tip bolts to the end of the muffler unlike the 1.7 which has a couple of configs. I have one muffler and will check to see what it is. And I have the cup for the end of the rear side shift rod. Bruce Thanks, Bruce, for the info...and for looking. And, as a cautionary tale....I bought a nice set of used stainless steel heat exchangers. I am hearing "rumblings" that they may also be an issue with mating a muffler to a 74 1.8, so perhaps be forewarned.... Will update as the saga progresses. |
malcolm2 |
Dec 16 2016, 09:19 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I bought a new turn signal lever for a super beetle. I would suppose the wiper lever would be the same too.
Lo-Fi Version | Time is now: 15th May 2024 - 11:13 PM |
