Subaru Transmission Block Off Plates and Hydraulic Clutch Mount, Block-Offs $45, Hydraulic Clutch mounts $65 I have 10 of each! |
rnellums |
Dec 15 2016, 07:37 PM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
I'm going to put another order in for some block off plates for the Subaru transmission conversions. It's a simple 1/8" laser cut aluminum plate with the holes in the right places. I will be putting in the order Monday, to take payment once they ship.
Attached image(s) |
Chris H. |
Dec 28 2016, 09:09 AM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Because the level is not accurate sometimes with the dipstick since the trans is pointing slightly downward in the stock Subaru setup. Many conversion people have theirs level or tail end just a bit up like a 914's. In those cases you need more oil than the stick would indicate to cover the uphill section since it's calibrated for stock. If there's not enough gear oil it can cause a whine and premature wear of the higher gears. Mostly it's just that you wouldn't have to worry about it. Is there too much? Not enough? Is it dirty? Should I change it? Probably fine 99% of the time but for what...$25 extra you could see the level? I'd have that.
Lo-Fi Version | Time is now: 17th May 2024 - 03:14 PM |
