Subaru Transmission Block Off Plates and Hydraulic Clutch Mount, Block-Offs $45, Hydraulic Clutch mounts $65 I have 10 of each! |
turnaround89 |
Jan 18 2017, 05:44 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
Pm sent about block off plate and clutch bracket
rnellums |
Jan 18 2017, 09:39 PM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
Looks Like I ran out of the clutch master cylinder brackets. Need to put in another order for some more!
turbonet |
Jan 18 2017, 11:05 PM
Member Group: Members Posts: 68 Joined: 14-September 16 From: Vancouver Member No.: 20,398 Region Association: Canada |
I'll take a block off plate.
turnaround89 |
Jan 19 2017, 08:05 PM
Do you accept PayPal?
rnellums |
Jan 19 2017, 11:24 PM
turnaround89 |
Jan 20 2017, 12:34 PM
Awesome. I was a little worried since you hadn't replied to my pms. Can't wait for the parts to be ready. Let me know when you want me to send payment. Thanks again.
rnellums |
Dec 3 2017, 09:41 AM
I just had another run of these (~10 each) made if anyone is interested!
Costa05 |
Dec 3 2017, 07:33 PM
Member Group: Members Posts: 320 Joined: 27-October 16 From: Phoenix, Arizona Member No.: 20,535 Region Association: Southwest Region |
How did the prototype for the cable shifter bracket work out. Any pics avail?
turnaround89 |
Dec 4 2017, 10:05 PM
Can I get a hydraulic clutch mount?
rnellums |
Dec 4 2017, 10:44 PM
How did the prototype for the cable shifter bracket work out. Any pics avail? It came out ok. Its currently being used, but had to be pretty heavily modified along the way to get the throw right. The Coldwater setup is really pretty well thought out and put together (what I currently run on Apollo). My prototype works, but still need more polishing before its ready. Can I get a hydraulic clutch mount? PM sent |
Amenson |
Dec 28 2017, 01:27 PM
That's opposite lock!! Group: Members Posts: 645 Joined: 27-May 05 From: Dublin, OH Member No.: 4,154 Region Association: None |
I just tried mocking this up using several different Tilton and Wilwood master cylinders I have and the bolt spacing and center hole size id different.
Which master cylinder is intended to be used with this plate? |
rnellums |
Dec 28 2017, 06:55 PM
I just tried mocking this up using several different Tilton and Wilwood master cylinders I have and the bolt spacing and center hole size id different. Which master cylinder is intended to be used with this plate? Its a Honda MC 5/8", 1993-2000 civic. Original pioneering work done by Kent and Chris Here starting at post #499 http://www.914world.com/bbs2/index.php?sho...1776&st=480 The process if pretty well illustrated in Ray's thread here, starting around post #111 http://www.914world.com/bbs2/index.php?sho...20569&st=90 Pictures of my install here, Starting at post 15: http://www.914world.com/bbs2/index.php?sho...300932&st=0 I drilled a small hole for the front of the master cylinder to pass through (and sealed it with a rubber grommet from Ace). Seems like I may need to do a more fully illustrated write up. Maybe next week once I get home I can put the car up and do more of a walk through. |
JRust |
Feb 8 2018, 10:22 PM
914 Guru Group: Members Posts: 6,305 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
I need the MC conversion plate. You still have some?
brettrarnold |
Feb 8 2018, 11:45 PM
New 914 owner in Lakewood CO Group: Members Posts: 89 Joined: 11-September 15 From: Lakewood, Colorado Member No.: 19,149 Region Association: Rocky Mountains |
I think one would work with what i have planned. I want one.
-Brett |
nnowa07 |
Jul 31 2019, 08:47 PM
Newbie Group: Members Posts: 5 Joined: 11-April 19 From: San Miguel, CA Member No.: 23,034 Region Association: Central California |
Still making block off plates? I'm joining the EZ30 crew, and need all the goodies. (IMG:style_emoticons/default/smile.gif)
rnellums |
Jul 31 2019, 08:51 PM
Still making block off plates? I'm joining the EZ30 crew, and need all the goodies. (IMG:style_emoticons/default/smile.gif) Not making them, but I still have a stock left over. Only problem Is I’m bad at shipping them out (IMG:style_emoticons/default/biggrin.gif) |
nnowa07 |
Jul 31 2019, 10:00 PM
Still making block off plates? I'm joining the EZ30 crew, and need all the goodies. (IMG:style_emoticons/default/smile.gif) Not making them, but I still have a stock left over. Only problem Is I’m bad at shipping them out (IMG:style_emoticons/default/biggrin.gif) PM sent! |
brettrarnold |
Aug 1 2019, 04:42 PM
Hey Ross can I get one of each?
Lo-Fi Version | Time is now: 3rd May 2024 - 06:47 AM |
