Heater Blower Update Kit; 914 |
dgraves |
Dec 15 2016, 09:30 PM
1974 914 2.0 Group: Members Posts: 180 Joined: 6-June 16 From: Montana Member No.: 20,076 Region Association: Rocky Mountains |
Has anyone had any experience with installing a Heater Blower Update Kit; 914 1970-76 from the Auto Atlanta website? Was there a noticeable improvement in the heat and defrost output? Thank you.
bandjoey |
Dec 15 2016, 09:36 PM
bandjoey Group: Members Posts: 4,925 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Is that the fan attachment for two hoses?
If that's what they're doing and I'm not sure what the kit includes you could probably buy those parts off the members here for less Post a link a description or some pictures |
Mikey914 |
Dec 16 2016, 12:17 AM
The rubber man Group: Members Posts: 12,661 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
If I recall, it's a spliter and hoses.
cary |
Dec 16 2016, 07:57 AM
When we were in Montana and the boys drove both cars everyday I fabricated brackets and ran duel fan motors.
Tried the splitter first. A bit better, not enough. |
dgraves |
Dec 16 2016, 07:13 PM
Thanks, everyone. It is a splitter for engine compartment fan.
bandjoey |
Dec 16 2016, 07:48 PM
Post in the classifieds and you'll find the splitter I'll bet. hose is available at FLAPS or perhaps 914rubber.com.
http://www.914world.com/bbs2/index.php?sho...8&hl=heater here u go. this one is sold but there are others out there. post away (IMG:style_emoticons/default/biggrin.gif) |
ConeDodger |
Dec 16 2016, 07:52 PM
Apex killer! Group: Members Posts: 23,584 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Not sure exactly where it is but I have the splitter. Never put it on. Bought it used from a member. (IMG:style_emoticons/default/evilgrin.gif)
3d914 |
Dec 19 2016, 06:56 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
Just my $.02, but from my experience in sunny AZ & NM, a single rear fan motor on my 2.0L didn't work that great. I ended up doing dual fan motors (one one each side feeding into the J-pipe) and the result was decent. It would defrost the windshield quickly.
Good luck. |
Tbrown4x4 |
Dec 19 2016, 11:09 PM
Senior Member Group: Members Posts: 703 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
I'd like to find out what the CFM output of the stock fan is. I would like to run dual fans eventually as well.
IronHillRestorations |
Dec 20 2016, 08:02 AM
I. I. R. C. Group: Members Posts: 6,717 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
The splitter sort of works, but the stock fan really doesn't have enough CFM for two hoses. Dual fans would be better. I don't know what the draw on one fan is, but to be safe you should switch the 2nd fan with a separate relay.
Olympic 914 |
Dec 20 2016, 09:32 AM
Group: Members Posts: 1,663 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Where and how did you guys mount the second fan?
Pics would be nice also. |
carcus |
Dec 22 2016, 01:17 AM
Member Group: Members Posts: 223 Joined: 16-March 16 From: Colorado Springs Member No.: 19,760 Region Association: Rocky Mountains |
Gets below zero quite a bit here and I have not had an issue with the stock setup. Sometimes it will burn my face off and have to pull the knob off. I just wear a jacket and jeans. I think the best thing for me was new rubber on the T tops and doors.
TheCabinetmaker |
Dec 22 2016, 08:14 AM
Your 914 has t tops?
914werke |
Dec 22 2016, 03:02 PM
"I got blisters on me fingers" Group: Members Posts: 10,058 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
if you want dual fans & want to get fancy (IMG:style_emoticons/default/smile.gif)
scott_in_nh |
Dec 23 2016, 09:30 AM
Senior Member Group: Members Posts: 808 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States |
The splitter does a good job of distributing the heat to both sides of the car evenly, but I will agree with those who say duel fans are better, because to cfm is so low once split.
I'd like to know what fans you are using as the single factor fan seems bulky, doesn't put out a lot of cfm, and likely has a high amp draw. I was thinking about trying the blowers used for inboard boats.... |
Lo-Fi Version | Time is now: 13th May 2024 - 04:28 PM |
