Bleeding front brakes |
tomh |
Dec 17 2016, 08:25 PM
Member Group: Members Posts: 322 Joined: 28-February 10 From: san jose Member No.: 11,412 Region Association: None |
Getting ready to install the front calipers and realized there are 2 bleeders. What's the process on using 2 bleeder valves to bleed the brakes, I usually just use my bleeder cup with a single hose and start pumping but have never had calipers with 2 ports.
Thanks |
rmdinmd |
Dec 17 2016, 08:40 PM
Member Group: Members Posts: 488 Joined: 30-October 13 From: Greeneville,Tn Member No.: 16,585 Region Association: South East States |
use the top one for bleeding air; the bottom one is for bleeding out the old fluid.
tomh |
Dec 17 2016, 08:57 PM
Ok, that makes sense to me.
Thanks |
tomh |
Dec 17 2016, 11:51 PM
Refresh my memory on this, after doing the brake job and bleeding is there a switch to reset on the master cylinder for the blinking light on the dash. Its been about 7 years since I've done a brake job on a 914.
Thanks |
TravisNeff |
Dec 18 2016, 10:23 AM
Yes on the side of the master cylinder where the electrical connection is there is a switch
Lo-Fi Version | Time is now: 9th June 2024 - 11:32 PM |
