tomh
Dec 17 2016, 08:25 PM
Getting ready to install the front calipers and realized there are 2 bleeders. What's the process on using 2 bleeder valves to bleed the brakes, I usually just use my bleeder cup with a single hose and start pumping but have never had calipers with 2 ports.
Thanks
rmdinmd
Dec 17 2016, 08:40 PM
use the top one for bleeding air; the bottom one is for bleeding out the old fluid.
tomh
Dec 17 2016, 08:57 PM
Ok, that makes sense to me.
Thanks
tomh
Dec 17 2016, 11:51 PM
Refresh my memory on this, after doing the brake job and bleeding is there a switch to reset on the master cylinder for the blinking light on the dash. Its been about 7 years since I've done a brake job on a 914.
Thanks
TravisNeff
Dec 18 2016, 10:23 AM
Yes on the side of the master cylinder where the electrical connection is there is a switch
