Double or Single Adjustable Konis???, Worth the $70 difference in price?? |
groot |
Apr 28 2005, 05:31 AM
Dis member Group: Members Posts: 894 Joined: 17-December 03 From: Michigan Member No.: 1,444 |
Mike,
I agree with Brad, stick with the singles for your application. To use the Koni 8611s (I have them on my fronts) you have to figure out a way to adjust the bump setting, which is on the bottom of the strut. So you either have to make a slot in the bottom of the strut housing or come through the ball joint to get at the adjuster... or remove the strut cartridge to adjust bump. I have a different setup, so I can get to my bump adjustment, but I still have to remove the wheel to do it. |
Mueller |
Apr 28 2005, 08:57 AM
yea...I know, Brad is normally correct (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) ... it's tough knowing that there are other options available and for some odd reason I love the idea of being able to fine tune/tweak the suspension (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) |
groot |
Apr 28 2005, 10:00 AM
Adjusting rebound, alignment, spring rates and tire pressures give you plenty of knobs to tweak.
rhodyguy |
Apr 28 2005, 10:08 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,072 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
for the money you can't go wrong with the yellows, imho. interesting attachment re the koni advice. confirms exactly what i discovered while driving home with the rebound turned up.
k |
Mueller |
May 17 2005, 08:12 PM
Hey Brad or Andy...hurry up and add the rear Konis to the club store.....I just got my tax returns today and I'm ready to purchase all 4 corners (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif)
Lo-Fi Version | Time is now: 5th May 2024 - 12:33 PM |
