Front Caliper rebuild help |
branston |
Dec 23 2016, 05:38 PM
Member Group: Members Posts: 89 Joined: 17-October 12 From: Michigan Member No.: 15,053 Region Association: Upper MidWest |
I see lots of rear caliper rebuild threads but haven't found anything specifically front caliper.
Mine are partially dismantled and I'm looking for a a procedure or video. have tried the search here but nothing useful found. Can anyone help. Thanks |
Spoke |
Dec 23 2016, 07:01 PM
Many folks go to Eric Shea here for his caliper "restoring" services. It's money well spent. His website is www.pmbperformance.com. The calipers you will receive from Eric look like they've just come off the assembly line.
BTW, (IMG:style_emoticons/default/welcome.png) |
colingreene |
Dec 23 2016, 08:44 PM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
I was going to say the help you need is to box them up and mail them to Eric, hes the best. Hes done two sets of calipers for me now.
branston |
Dec 23 2016, 09:12 PM
I'm half way through the job so won't be shipping them to him, however his website has detailed info and a downloadable .pdf of the braking section of the workshop manual elsewhere got me out of the weeds tonight.
His calipers look awesome and perhaps if Santa doesn't bring me a set I may invest in the new year. thanks for your help. |
turnaround89 |
Dec 24 2016, 04:34 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
Not sure if this will help but here is an awesome video done by PMB for the rear calipers. If you can rebuild the rear calipers, a lot of it will simply transfer to doing the fronts.
Rear Brake Caliper Rebuild Video If I recall 914 front calipers need to be split apart similar to the rear calipers. I'd suggest watching the video and you should be able to learn quite about caliper rebuilds in general. |
Lo-Fi Version | Time is now: 14th May 2024 - 07:37 PM |
