Valve lifter broke off!, During assembly - just fell apart |
larss |
Dec 25 2016, 11:00 AM
Member Group: Members Posts: 428 Joined: 10-September 09 From: Sweden Member No.: 10,787 Region Association: Scandinavia |
During assembly of my stock -70 1.7 I was by hand wiggeling in the #4 exhaust lifter and it fell apart (IMG:style_emoticons/default/blink.gif) , no force at all was used. All other lifters seems OK, should be stock lifters.
Have been running this engine for the last 50000 of its 100000 miles, did not notice any strange sounds last time I started it which was a short run after sitting for 10 years. Only thing I can remember as strange was one rocker shaft came lose for about 4000 miles ago...retightened it and everything looked OK...dont remember if it was this side though and if it could have any influence(?) Looking at the broken ends (pic at the bottom) it seems that some of the fracture is hammered (but not wery much) so it might be that it broke during running. What can the reason be and is this a known issue with Type4 lifters? //Lars S (IMG:http://www.914world.com/bbs2/uploads_offsite/www.lsmteknik.se-10787-1482685214.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.lsmteknik.se-10787-1482685215.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.lsmteknik.se-10787-1482685216.3.jpg) |
rgalla9146 |
Dec 25 2016, 11:26 AM
Advanced Member Group: Members Posts: 4,552 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
That may have been broken for a while but was kept by the lifter bore.
Is it a stock lifter ? |
larss |
Dec 25 2016, 11:29 AM
euro911 |
Dec 25 2016, 01:26 PM
Do you need a lifter? ... I have some decent spares
larss |
Dec 25 2016, 01:28 PM
Krieger |
Dec 25 2016, 02:49 PM
Advanced Member Group: Members Posts: 4,707 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Did you give a look at the bore it came out of? Hopefully there is no damage from the debris.
barefoot |
Dec 25 2016, 08:28 PM
Senior Member Group: Members Posts: 1,273 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Can't imagine the fatigue cycles that could have caused this, only thing I can think of is that the insert that the pushrods sockets into was slightly mis-aligned in the bore that set up a cyclic stress ultimately resulting in fracture. Looks like it's been fractured for a while as the surfaces look dull, or could be just dirty oil.
HAM Inc |
Dec 25 2016, 08:41 PM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
It's possible that when the rocker arms came loose that excessive lash damaged the follower. I would consider taking a look at the valve tips.
And since the engine sat for so long I would also look the valve springs over for rust. Couldn't begin to tell you how many heads I've had in the shop from engines that sat for years that had rusty springs. Even from engines stored indoors. |
larss |
Dec 26 2016, 12:37 AM
larss |
Dec 26 2016, 01:13 AM
It's possible that when the rocker arms came loose that excessive lash damaged the follower. I would consider taking a look at the valve tips. And since the engine sat for so long I would also look the valve springs over for rust. Couldn't begin to tell you how many heads I've had in the shop from engines that sat for years that had rusty springs. Even from engines stored indoors. All valve tips looks good also the groove in the lifter where the pushriod rests looks as it should...will take a look at the springs, thanks! //Lars S |
Valy |
Dec 26 2016, 11:42 AM
Senior Member Group: Members Posts: 1,675 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
I would take a very careful look at the camshaft lobe bellow that lifter. It could be that vibrations from the friction with the lobe caused that.
Check the oil passafes in that area too. I don't like the pitting on the sides. Those lifters are usually very smooth. Are all your lifters like that? Look in my build thread (signature) for the pictures of my new lifters. |
Mark Henry |
Dec 26 2016, 11:59 AM
Only time I've ever seen something like that is using 2 lifters and a BFH to hammer the ends onto custom pushrods. (IMG:style_emoticons/default/smash.gif)
Are you sure that's a one piece lifter? (IMG:style_emoticons/default/confused24.gif) Look down the cup end of one of the other lifters for a small circlip. |
larss |
Dec 26 2016, 01:27 PM
I would take a very careful look at the camshaft lobe bellow that lifter. It could be that vibrations from the friction with the lobe caused that. Check the oil passafes in that area too. I don't like the pitting on the sides. Those lifters are usually very smooth. Are all your lifters like that? Look in my build thread (signature) for the pictures of my new lifters. Thanks! Have put everything back together now (with a spare lifter!) Did check all cam lobes but everything looked normal. Thanks again! Lars S |
larss |
Dec 26 2016, 01:30 PM
Only time I've ever seen something like that is using 2 lifters and a BFH to hammer the ends onto custom pushrods. (IMG:style_emoticons/default/smash.gif) Are you sure that's a one piece lifter? (IMG:style_emoticons/default/confused24.gif) Look down the cup end of one of the other lifters for a small circlip. Thanks! ...Have owned the engine since 1980 so the chance for non stock liftet is small but I will have a close look when Im back home. Thanks again! Lars S |
Lo-Fi Version | Time is now: 13th May 2024 - 11:10 PM |
