How to inspect the underside and longs without a lift, now the Not another novice project thread |
seanpaulmc |
Dec 25 2016, 04:26 PM
Member Group: Members Posts: 300 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States |
I've just purchased a '73 914 and owned it long enough to ship it to Orlando and take it to go get titled. With only having it for this short period my list of concerns is growing. I have no intentions of driving the car around until I can assess how rusty it is. I appreciate the support and responses to the questions about transportation and engine identification. This is a superb community.
What advice do you have for lifting the car to inspect underneath and such without having access to a lift? I have read some of the build threads on here and you guys have some amazing shops and do incredible work! ...one day. But, at this point I don't have that. For now I'd like to lift the car, take the wheels off, and take the longitudinal covers off to get a good look at the structural areas of the car. However, I have concerns because this is a snowbelt car and I've read the stories about putting a floor jack through a rusted out car. Where should I lift with the floor jack (trust the jacking points?, other areas) and where should I put the jack stands so that I can poke around some and get pictures? Merry Christmas!!! |
branston |
Dec 25 2016, 10:01 PM
Member Group: Members Posts: 89 Joined: 17-October 12 From: Michigan Member No.: 15,053 Region Association: Upper MidWest |
I don't jack my '74 under the body, I tend to use the engine cross member close to the outer mounting bolts or under the bolt itself, and use the front suspension to lift the front. My own car is a mid west car and in remarkably good shape for a car from this area.
However removal of the outer rockers revealed rust close to the jack points affecting the longs. this my first 914 and have learned much, a quick check if to insert a jack into the jack point and see how much it moves when you try to lift it, don't lift it just try to see how much it moves. To my horror the jack point moved freely by hand! Go ahead and remove the outer rockers, removing mine which on the surface showed little signs of rust revealed dirt trap Porsche designed, mud and moisture accumulate in this area and the rot starts, once inside it rots the underside of the longs. I've attached photos of what was hiding behind the outer rocker on my car you can see the mud accumulated between the jack point and the reinforcing gusset. Attached image(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 08:44 PM |
