A 2x4 can distribute the load from the jack across a larger area of the floor pan. You can try that if you want to lift the car.
QUOTE(seanpaulmc @ Jan 31 2017, 03:01 PM)
A few questions/observations:
1. Are those unconnected wires laying at the back of the tunnel (brown and black) for the light that is supposed to be in the backpad? (Missing)
Yes, that's what they're for. Tape up the black wire to keep it from shorting to ground; it should be "live" all the time.
2. Any idea what the little brass metal piece laying next to the wires is for? It doesn't seem to be for the light.
It isn't for the light. Not sure what it might be for, possibly something inside the turn signal switch mechanism? There is an angled brass piece in there that loves to go AWOL when the steering column is taken apart.
3. Looks moist and nasty inside that tunnel.
Kinda typical. Worse than most I've seen here in CA, but we are a bit less rust-prone than many other areas.
4. How is the pad affixed to the firewall? How is it removed? Should it be retained and reused?
Which pad? There are three that I can think of.
1- The "back pad" that is the upholstered part that sits on the firewall. The interior light snaps into this part. It is held on by a pair of clips and four screws. The screws are about 6" up from the floor, I think, two in each seat well. Remove those screws, remove the engine-lid pull knob and the "escutcheon" around the knob, slide the bottom of the back pad forward and push the top of the pad down. It should come away from the firewall. (The seats need to be out, obviously.)
2- The tar insulation on the interior of the firewall, that is uncovered when the back pad is removed. This must be scraped off, like the other insulation.
3- The heavy rubber-covered mat on the engine side of the firewall. This is held in with a combination of glue and screws with very large plastic washers, and metal tabs on the edges. The actual function of this pad is to trap water against the firewall, leading to rust perforations. Ditch it.
5. Behind the driver's seat you can see three new wires (black, green, and blue) going through the floor to routed to the engine bypassing whatever original equipment isn't working.
Learn the acronym DAPO. (The PO stands for "previous owner". I'll let you guess the rest.) You may wind up using it a lot.
6. After chipping away at the loose material on the floor daylight is observed along the passenger long.
Never a good thing. I see door braces and welding in your future...
7. Retaining bolt for the passenger seatbelt at the floor was a total PITA to get out.
Penetrating oil, like PB Blaster or Aero Kroyl, can help a lot. WD-40 is a lousy penetrating oil, BTW.
8. How does the wooded piece on the passenger footwell come out? Seems brittle.
Wooded? Do you mean the styrofoam plug in the front of the passenger footwell? I think that may be glued in--I haven't messed with it myself, but have seen several out of the car.
The wood floorboard on the driver's side is held in with two or three bolts (likely Allen-head) and has to be turned to a fairly specific angle in order to maneuver it off of the pedals.
--DD
