How to inspect the underside and longs without a lift, now the Not another novice project thread |
seanpaulmc |
Dec 25 2016, 04:26 PM
Member Group: Members Posts: 300 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States |
I've just purchased a '73 914 and owned it long enough to ship it to Orlando and take it to go get titled. With only having it for this short period my list of concerns is growing. I have no intentions of driving the car around until I can assess how rusty it is. I appreciate the support and responses to the questions about transportation and engine identification. This is a superb community.
What advice do you have for lifting the car to inspect underneath and such without having access to a lift? I have read some of the build threads on here and you guys have some amazing shops and do incredible work! ...one day. But, at this point I don't have that. For now I'd like to lift the car, take the wheels off, and take the longitudinal covers off to get a good look at the structural areas of the car. However, I have concerns because this is a snowbelt car and I've read the stories about putting a floor jack through a rusted out car. Where should I lift with the floor jack (trust the jacking points?, other areas) and where should I put the jack stands so that I can poke around some and get pictures? Merry Christmas!!! |
seanpaulmc |
May 8 2022, 06:33 PM
Passenger Jack Point repair:
Peeing back the onion. The jack tube, from the factory, is only welded on each side. No welds top or bottom of the tube. TAMO. (Then a Miracle Occurs) Should have taken more pictures. I replaced both inner and outer layers with hand formed 16 ga. Trying to avoid cutting the fender away I chose to cut out to the top of the jack tube because the metal above was solid and could be welded to with the new. To make it recess for the jack tube, the panel needed relief cuts that got weld once installed. View from fender. With the RD pyramid cover installed. It will be so much fun to do the other side now. (IMG:style_emoticons/default/av-943.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 08:27 PM |
