Cleaning the inside of the oil cooler, ...how to do it effectively? |
larss |
Dec 26 2016, 07:50 AM
Member Group: Members Posts: 428 Joined: 10-September 09 From: Sweden Member No.: 10,787 Region Association: Scandinavia |
During the 1st tear down of my 100.000 mile stock 1.7 engime I filled the oil cooler with some detergent and let it sit overnight.
What came out was wery similar to a Guinnes Stout, also there was a lot of dirt sunk down to the bottom of the jar. Did a second fill and what came out the day after was more like strong coffe butno dirt in the bottom. My feel is that this may have affected the cooling significantely and to clean the inside of the oil cooler when there is a chance is a must. Is there a more effective way to clean it? /Lars S (IMG:http://www.914world.com/bbs2/uploads_offsite/www.lsmteknik.se-10787-1482760227.1.jpg) Dirt from the bottom of the jar: (IMG:http://www.914world.com/bbs2/uploads_offsite/www.lsmteknik.se-10787-1482760228.2.jpg) |
ConeDodger |
Dec 26 2016, 07:58 AM
Apex killer! Group: Members Posts: 23,587 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
It's a replacement item. (IMG:style_emoticons/default/barf.gif)
dlee6204 |
Dec 26 2016, 08:21 AM
(IMG:style_emoticons/default/agree.gif) Just replace it with a new one. |
Krieger |
Dec 26 2016, 09:05 AM
Advanced Member Group: Members Posts: 4,711 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
There are businesses that specialize in cleaning oil coolers ultrasonically. They will also pressure test them for leaks. Gasoline is also a good cheap solvent.
IronHillRestorations |
Dec 26 2016, 09:10 AM
Unless you can find a place that specializes in cleaning contaminated oil coolers, that thing is a goner.
6freak |
Dec 26 2016, 09:26 AM
id try boiling with some dawn dish soap if that dont work ,,I agree buy new....and gas is for running your car not cleaning it JMO...1 spark and well you know the rest...good luck
(IMG:style_emoticons/default/smile.gif) |
larss |
Dec 26 2016, 10:13 AM
Thanks all, didnt know that! Can see that the prices for new coolers vary a lot...wich coolers should I avoid/go for? Lars S |
Dec 26 2016, 10:53 AM
A quick google search revealed you can get a new one for less than $150, this is a no-brainer. I'd try and find one that wasn't made in Brazil or China
eyesright |
Dec 26 2016, 11:10 AM
Member Group: Members Posts: 430 Joined: 8-January 12 From: OK Member No.: 13,979 Region Association: Southwest Region |
Wow! That engine was still running? Show us the crank journals and etc...we gotta see this!
Elliot Cannon |
Dec 26 2016, 01:24 PM
If you really MUST keep the old one, send it here. (IMG:style_emoticons/default/biggrin.gif) http://oilcoolers.com/
larss |
Dec 26 2016, 01:38 PM
injunmort |
Dec 26 2016, 03:06 PM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
i put my last one in old turkey fryer with tsp from lowes, i keep the temp under boiling. it cleaned it right out. used the same setup as a hot tank for the oily bits as well.
maf914 |
Dec 26 2016, 03:53 PM
A new replacement seems to be reasonably priced at US $79.95 from aircooled.net. I don't know what the price may be in Sweden.
http://vwparts.aircooled.net/Oil-Cooler-Ty...21-117-021b.htm |
Mikey914 |
Dec 26 2016, 03:57 PM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Radiator shops can do this. Steam clean and pressure test.
North Coast Jim |
Dec 26 2016, 05:30 PM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
For the price you pay to attempt to clean it I would purchase new. Gives a new life to a valuable component as well
Jake Raby |
Dec 27 2016, 12:32 AM
The new units cool 10-15% less than the OEM units. I have even seen them out of the box with sand inside them. I no longer use them, and haven't for a few years now.
Ultrasonic cleaning is the only way to go, in a real machine, not a little toy. All 3 of mine are 20K watts and heat to 210F, you should see what comes out of an oil cooler after 20 minutes in the ultrasonic. |
gonzo54 |
Oct 20 2022, 09:13 AM
Orange Crush Group: Members Posts: 224 Joined: 10-May 19 From: Seal Beach, CA Member No.: 23,112 Region Association: Southern California |
Old thread-I'm looking for a Southern California Company to ultrasonic clean and test my oil cooler and I don't want to spend the "Aircraft Certification" price that Pacific Oil Cooler Service charges-any recommendations?
Thanks |
Lo-Fi Version | Time is now: 16th May 2024 - 07:51 PM |
