door trim |
door trim |
JFG |
Dec 27 2016, 10:29 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
The piece that sits on the lip which contains the spot welds and runs from the windshield frame down, across and back up to the roll bar.
A pillar and b pillar have trims (not yet fitted) and then there's the dashboard. As i lost my strip down pics i have no point of reference. Finally on the door seal itself how does the fold over piece from triangle glass seat with the door mounted seal? |
Mikey914 |
Dec 27 2016, 12:08 PM
The rubber man Group: Members Posts: 12,661 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
1- sound as like what I call the inner door seal. It's on the body and slides over the pinch welded pieces. The new seals press onto the seam with the bulb out. To the door.
2- the a and b pillar trims are not interchangeable. Should be pretty easy to sort out (they attach via screws). 3-the outer door seal (as I refer to it) butts up to the triangle window seal base. And runs the length of the track to the door handle area. If you are installing mine, it's a solid neoprene, and is easier to install by stretching to make thinner, pushing into the track, and letting it expand. Makes a very solid seal that will not pick up water. Unlike the OEM sponge rubber. |
Lo-Fi Version | Time is now: 13th May 2024 - 11:58 PM |
