JFG
Dec 27 2016, 10:29 AM
The piece that sits on the lip which contains the spot welds and runs from the windshield frame down, across and back up to the roll bar.
A pillar and b pillar have trims (not yet fitted) and then there's the dashboard. As i lost my strip down pics i have no point of reference.
Finally on the door seal itself how does the fold over piece from triangle glass seat with the door mounted seal?
Mikey914
Dec 27 2016, 12:08 PM
1- sound as like what I call the inner door seal. It's on the body and slides over the pinch welded pieces. The new seals press onto the seam with the bulb out. To the door.
2- the a and b pillar trims are not interchangeable. Should be pretty easy to sort out (they attach via screws).
3-the outer door seal (as I refer to it) butts up to the triangle window seal base. And runs the length of the track to the door handle area. If you are installing mine, it's a solid neoprene, and is easier to install by stretching to make thinner, pushing into the track, and letting it expand. Makes a very solid seal that will not pick up water. Unlike the OEM sponge rubber.
