WTB Rebuilt Fuel Pump for 1972 1.7, WTB Rebuilt Fuel Pump for 1972 1.7 |
itsmagic |
Dec 28 2016, 01:08 PM
Newbie Group: Members Posts: 10 Joined: 3-June 05 From: Hyde Park, NY Member No.: 4,193 |
The electric motor on my fuel pump seems to have crapped out. I can get it going briefly by tapping, but thats it. Probably bad armature brush's. Does anyone have a rebuilt 3 port fuel pump for sale? Alternatively, can you recommend someone who can rebuild mine? Thanks for any info.
TheCabinetmaker |
Dec 28 2016, 01:25 PM
Buy a new Bosch 2 port pump. About $100 bucks. #69133.
itsmagic |
Dec 28 2016, 01:34 PM
Thanks! Stupid question: On the new two port pump, Obviously one line is suction, the other is pressurized. What do I do with the return line hose attached to the original pump?
TheCabinetmaker |
Dec 28 2016, 02:34 PM
Eliminate it. I would also relocate the pump away from the heater dump valve. Might also be a good time to install steel lines in the tunnel and replace all the old rubber hoses
itsmagic |
Dec 28 2016, 04:04 PM
Thank you very much for the information and advice! I'll just eliminate the return line at the Y connector (or possibly just block it off).
brownaar |
Dec 28 2016, 05:23 PM
Member Group: Members Posts: 263 Joined: 23-September 04 From: Gate City, VA Member No.: 2,813 Region Association: None |
I just made the switch to a two-port pump after chasing fuel delivery demons with the 40+ year old three-port pump. Best thing I ever did. This is a pic I hijacked from somebody else's thread but it shows pretty much how I set mine up. You can buy a nice 52mm aluminum mounting bracket with a rubber insert on ebay for about 20 bucks.
914_teener |
Dec 29 2016, 01:28 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
This is exactly how I did mine....more than several years ago. Unless you want a concours car, this is the way to go. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:32 PM |
