-6 2.4 pistons and cylinder value? |
mb911 |
Dec 28 2016, 04:25 PM
914 Guru Group: Members Posts: 6,850 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I am having a hard time coming up with a value on some good used 2.2,2.4 mfi pistons and cylinders. These are oem not off brand. Any help in pricing would be much appreciated.
Have new s pistons and cylinders going in instead. |
sixnotfour |
Dec 28 2016, 04:31 PM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
They are either 2.2 or 2.4 the compression is different due to stroke difference,
Not much but 2.2s in a 2.4. Is a little bump in compression. Call EBS they have news J&E pistons and overbore cylinder sets.. |
mb911 |
Dec 28 2016, 05:09 PM
They are either 2.2 or 2.4 the compression is different due to stroke difference, Not much but 2.2s in a 2.4. Is a little bump in compression. Call EBS they have news J&E pistons and overbore cylinder sets.. Right I have 2.4 t p&c and want to know value. I already have s pistons and cylinders that I am using.. Just want to know what is a fair price to ask for my set of mfi pistons and cylinders I am not going to use. |
sixnotfour |
Dec 28 2016, 07:06 PM
sixnotfour |
Dec 28 2016, 07:11 PM
unless you measure them or know the mileage, they are cores for rebore...
you said 2.2 - 2.4 not the same I am pretty sure you are doing 2.2 S because that's what is easily had right now, and is a great 2.4 upgrade.. |
Mark Henry |
Dec 28 2016, 07:27 PM
I'd to go to the pelicanparts 911 for sale forum and do a search on 2.4 piston and cylinders for sale, then look at what others have asked for a similar set.
Here and there... peeps don't like answering the old "What's it worth" question. |
sixnotfour |
Dec 28 2016, 07:41 PM
cores with out specifics...iron cylinders.. Unless low miles..number's or data...
just reality |
brant |
Dec 28 2016, 10:55 PM
I agree with Jeff
He knows this market I know core values are on the rise But only a little while back I was disappointed with what I got out of iron cores in good shape |
mb911 |
Dec 29 2016, 07:21 AM
unless you measure them or know the mileage, they are cores for rebore... you said 2.2 - 2.4 not the same I am pretty sure you are doing 2.2 S because that's what is easily had right now, and is a great 2.4 upgrade.. These are cast iron cylinders no scoring. I will measure them out and clean and inspect but was curious if it was worth the time for example if they are worth 100 dollars then no not to me but if you are seeing sets sell for 3 to 750 well I guess it's worth it otherwise they become pencil holders. |
Mark Henry |
Dec 29 2016, 07:42 AM
Like I said check pelican parts (IMG:style_emoticons/default/rolleyes.gif)
It only took me 2 minutes to see something similar to what you have for sale at $250 for 2 month with only a nibble, no bites. Also saw a 2.2S set fully spec-ed out good sell for $1300 within days with other peeps in cue. But then that was only 2 minutes of looking and I'm not doing your work for you. (IMG:style_emoticons/default/bye1.gif) |
BK911 |
Dec 29 2016, 08:07 AM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
Like I said check pelican parts (IMG:style_emoticons/default/rolleyes.gif) It only took me 2 minutes to see something similar to what you have for sale at $250 for 2 month with only a nibble, no bites. Also saw a 2.2S set fully spec-ed out good sell for $1300 within days with other peeps in cue. But then that was only 2 minutes of looking and I'm not doing your work for you. (IMG:style_emoticons/default/bye1.gif) Nobody wants 2.4T pistons. They are the lowest compression of the 2.2 and 2.4 pistons. The cylinders have some value if not oval and are still within spec. Still have a little value if out of spec if they have enough meat to bore to 85mm. I have about 6 sets collecting dust. So I hope I am wrong!! |
mb911 |
Dec 29 2016, 08:34 AM
Like I said check pelican parts (IMG:style_emoticons/default/rolleyes.gif) It only took me 2 minutes to see something similar to what you have for sale at $250 for 2 month with only a nibble, no bites. Also saw a 2.2S set fully spec-ed out good sell for $1300 within days with other peeps in cue. But then that was only 2 minutes of looking and I'm not doing your work for you. (IMG:style_emoticons/default/bye1.gif) I looked as well and was looking here for some opinions.. Thanks everyone.. Maybe I will sell individual in ebay. |
brant |
Dec 29 2016, 09:53 AM
Like I said check pelican parts (IMG:style_emoticons/default/rolleyes.gif) It only took me 2 minutes to see something similar to what you have for sale at $250 for 2 month with only a nibble, no bites. Also saw a 2.2S set fully spec-ed out good sell for $1300 within days with other peeps in cue. But then that was only 2 minutes of looking and I'm not doing your work for you. (IMG:style_emoticons/default/bye1.gif) I looked as well and was looking here for some opinions.. Thanks everyone.. Maybe I will sell individual in ebay. They are matched as a set by height mixing and matching from different sets is tricky. If someone needs one from your height group then that is easy to sell not as likely that 6 someone's need one each |
mb911 |
Dec 29 2016, 10:29 AM
Like I said check pelican parts (IMG:style_emoticons/default/rolleyes.gif) It only took me 2 minutes to see something similar to what you have for sale at $250 for 2 month with only a nibble, no bites. Also saw a 2.2S set fully spec-ed out good sell for $1300 within days with other peeps in cue. But then that was only 2 minutes of looking and I'm not doing your work for you. (IMG:style_emoticons/default/bye1.gif) I looked as well and was looking here for some opinions.. Thanks everyone.. Maybe I will sell individual in ebay. They are matched as a set by height mixing and matching from different sets is tricky. If someone needs one from your height group then that is easy to sell not as likely that 6 someone's need one each Thanks I knew that but it is a good reminder so I advertise it that way.. Thanks for the insight everyone.. |
sixnotfour |
Dec 29 2016, 01:51 PM
2.7 cylinders are better pencil holders because they have aluminum fins and plated bore,,no nasty rust. more pen caocity also (IMG:style_emoticons/default/beerchug.gif)
mb911 |
Dec 29 2016, 01:56 PM
2.7 cylinders are better pencil holders because they have aluminum fins and plated bore,,no nasty rust. more pen caocity also (IMG:style_emoticons/default/beerchug.gif) I sold 5 2.7 cylinders with pistons welded in there with holes drilled in the top for pencils years ago for 100 dollars each.. |
sixnotfour |
Dec 29 2016, 02:05 PM
2.7 cylinders are better pencil holders because they have aluminum fins and plated bore,,no nasty rust. more pen caocity also (IMG:style_emoticons/default/beerchug.gif) I sold 5 2.7 cylinders with pistons welded in there with holes drilled in the top for pencils years ago for 100 dollars each.. there you go...I welded a handle and put a clear plexi bottom on one for a mug.. ZDUG DUGZ sells em too |
jmill |
Dec 29 2016, 03:31 PM
mb911 |
Dec 29 2016, 03:42 PM
I am pretty sure you are doing 2.2 S because that's what is easily had right now, and is a great 2.4 upgrade.. Where can these be easily had? I'm in need of a set along with a CW crank. Well my set with biral cylinders replated were 1600 but I have some good connections.. I would have done JE pistons in my current cylinders had I not found the deal I did. JE pistons have a really short skirt and not in a good way in my opinion. My 3.2 short stroke turbo engine had them and worked great but from a long term stability stand point I don't know. I have a heat exchangers client on this forum that has nearly 300k on his stock 2.4 less 1 time head rebuild.. That speaks to quality of the stock pistons and cylinders. |
Mark Henry |
Dec 29 2016, 04:00 PM
2.7 cylinders are better pencil holders because they have aluminum fins and plated bore,,no nasty rust. more pen caocity also (IMG:style_emoticons/default/beerchug.gif) I sold 5 2.7 cylinders with pistons welded in there with holes drilled in the top for pencils years ago for 100 dollars each.. there you go...I welded a handle and put a clear plexi bottom on one for a mug.. ZDUG DUGZ sells em too I got yo boitch's beat on the pencil holders.... mines a 3.6 LN Engineering nickies pencil holder. (IMG:style_emoticons/default/w00t.gif) Damn...I need to clean the damn thing..... (IMG:style_emoticons/default/dry.gif) Attached image(s) |
Lo-Fi Version | Time is now: 15th May 2024 - 05:01 AM |
