Side shifter lever, what parts wear out ?? |
porschetub |
Dec 29 2016, 12:44 PM
As per title,still having shifting issues need to know what can go wrong/wear out in this part that could cause me issues ?
I have all upgrade bushes,uni-joint @ firewall ,new clutch but it still pops out of gear in 4th,I can adjust the shifter (incorrectly) and it stays put and doesn't jump out of gear,however other gears get screwed up,I appear to have full movement/engagement at the gearbox,research indicates I may have bad bearing in the intermediate plate !!!!!,hope not. Thanks in advance. P.S. happy upcoming new year to all (IMG:style_emoticons/default/beerchug.gif) |
rhodyguy |
Dec 29 2016, 12:53 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,079 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Spent/worn detent/lockout plate, excessive wear on lever at plate contact point, springs gunked up with grease and dirt, the 2 bushing that cradle the spring on the bottom of the shift lever. Issues with all gears or a specific plane? Front to rear gears or side to side?
porschetub |
Dec 29 2016, 01:03 PM
Thanks Kevin,did an edit with more details,I might ad the lever appears not to follow the gate where ever it is adjusted to.
Box is supposed to be low mileage ??? (85,000kms) |
porschetub |
Dec 29 2016, 04:41 PM
Moderators can you please move this to the garage ,sorry and thanks (IMG:style_emoticons/default/beer.gif)
Mikey914 |
Dec 30 2016, 03:09 AM
The rubber man Group: Members Posts: 12,661 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
This is puzzling It will not pop out without the rubber if I recall?
rhodyguy |
Dec 30 2016, 11:50 AM
You're saying the lever does not make contact with the plate? (IMG:style_emoticons/default/unsure.gif) if so, getting into r/1st must be a pain.
porschetub |
Dec 30 2016, 01:06 PM
The detent plate appears to be working,changing down into first gear is ok,as I have repaired/updated all linkage parts I'am asking if the gearshift lever could be @ fault.
No matter how I adjust it using all suggested methods the gate isn't well defined especially when changing down,I take it carefully and it appears to help little. Made further adjustment last night and it will stay in 4th gear under power for a short time or just pops out of gear straight away. I think its the shift lever or the rear shift rod as that hasn't been made very well,maybe I should redo the whole thing. The front engine mount is a NOS stock -6 one and the rear gearbox mounts are new 911 type,the engine is firm in the car and moves little. |
Dec 30 2016, 09:17 PM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Typically the wear points on the gear shift lever are the hole through the lock plate, and the sides of the lever where it goes through the lock plate.
Sounds to me like you still have slop in the linkage. Doc Evil has modified a shift rake piece to build up the fingers of the rake where they engage with the shift rails in the transmission. Then file to a very precise fit--that eliminates some of the slop in the linkage that originates inside the gear box. But that shouldn't make it pop out of gear. If you can't get it to stay in gear, it is most likely that the synchro bands/hub and/or dog-teeth on the slider and gear are worn out. This requires a transmission rebuild to fix. Get Doc E's video on the subject for a thorough set of instructions. --DD |
carcus |
Dec 31 2016, 01:07 AM
Member Group: Members Posts: 223 Joined: 16-March 16 From: Colorado Springs Member No.: 19,760 Region Association: Rocky Mountains |
Linkage wears out also. I am dealing with that issue right now.
Lo-Fi Version | Time is now: 13th May 2024 - 08:29 PM |
