WebCam Mechanical Lifters, Lifters |
capitolatim |
Jan 3 2017, 02:28 PM
Member Group: Members Posts: 64 Joined: 11-June 15 From: capitola,ca Member No.: 18,841 Region Association: Northern California |
We are putting together a 103mm four. I have FAT barrels and pistons with their cam, T-4. They say use WebCam mechanical lifters. which I have 00-265.
The lifters have a cir-clip and it sounds like a piston in them that rattles. My engine guy said they look like hydraulic lifters. I called FAT and WebCam, they assured me they are not, and that's just the way they make them. Anyone have experience with these? Seems sort of weird to me. Cheers Tim |
worn |
Jan 3 2017, 02:34 PM
can't remember Group: Members Posts: 3,153 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
We are putting together a 103mm four. I have FAT barrels and pistons with their cam, T-4. They say use WebCam mechanical lifters. which I have 00-265. The lifters have a cir-clip and it sounds like a piston in them that rattles. My engine guy said they look like hydraulic lifters. I called FAT and WebCam, they assured me they are not, and that's just the way they make them. Anyone have experience with these? Seems sort of weird to me. Cheers Tim Mine were like that. I think they are just made of two pieces for some reason. The clip holds the push rod. |
Mark Henry |
Jan 3 2017, 03:17 PM
We are putting together a 103mm four. I have FAT barrels and pistons with their cam, T-4. They say use WebCam mechanical lifters. which I have 00-265. The lifters have a cir-clip and it sounds like a piston in them that rattles. My engine guy said they look like hydraulic lifters. I called FAT and WebCam, they assured me they are not, and that's just the way they make them. Anyone have experience with these? Seems sort of weird to me. Cheers Tim Mine were like that. I think they are just made of two pieces for some reason. The clip holds the push rod. The clip holds the lifter PR end cup in place, I believe it was the simplest way to heat treat the cup. Fat is recommending the WEB lifters because most likely it is a WEB cam. |
Lo-Fi Version | Time is now: 10th May 2024 - 02:24 PM |
