Throttle Hand Lever Interference with Appearance Group Console, Does anyone have both of these options together? |
jkb944t |
Jan 3 2017, 08:17 PM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
I installed the throttle hand lever last night and then tried to test fit the appearance group console tonight. I found that the throttle lever is too far forward to work as designed with the console.
Has anyone run into this situation before and found a solution? I am considering turning the throttle lever around 180 degrees but I am not sure yet if this would work correctly or not. Too tired tonight to figure anything out but was hopeful someone had dealt with this already. Jeff B |
Mikey914 |
Jan 3 2017, 10:38 PM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Interesting. As the consul was originally fro the later cars it was never really an "issue".
Looks like one of my consuls. If so I'd be willing to work with you to make a custom one. Mark |
jkb944t |
Jan 4 2017, 06:49 AM
Interesting. As the consul was originally fro the later cars it was never really an "issue". Looks like one of my consuls. If so I'd be willing to work with you to make a custom one. Mark Mark, You are correct that it is one of your consuls that I got just after Thanksgiving from you along with your throttle lever kit. I will definitely take you up on the custom offer once I have a better look at what options I have for modifying the lever travel. Thanks, Jeff B |
Lo-Fi Version | Time is now: 24th May 2024 - 02:21 PM |
