Throttle Hand Lever Interference with Appearance Group Console, Does anyone have both of these options together? |
jkb944t |
Jan 3 2017, 08:17 PM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
I installed the throttle hand lever last night and then tried to test fit the appearance group console tonight. I found that the throttle lever is too far forward to work as designed with the console.
Has anyone run into this situation before and found a solution? I am considering turning the throttle lever around 180 degrees but I am not sure yet if this would work correctly or not. Too tired tonight to figure anything out but was hopeful someone had dealt with this already. Jeff B |
jkb944t |
Jan 5 2017, 07:03 AM
Last night I rotated the hand throttle 180 degrees to see if that helped. It helped some but still would have interference with the vertical gauge board.
Then I tried shifting the vertical gauge board on the console forward at the bottom and it looks like this combination might work. I would just need to move the vertical gauge board support forward and then make a new longer version of the horizontal board. I still need to do some more test fitting to determine the exact length increase of the horizontal board that covers the shifter. Jeff B |
Lo-Fi Version | Time is now: 24th May 2024 - 06:20 PM |
