Throttle Hand Lever Interference with Appearance Group Console, Does anyone have both of these options together? |
jkb944t |
Jan 3 2017, 08:17 PM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
I installed the throttle hand lever last night and then tried to test fit the appearance group console tonight. I found that the throttle lever is too far forward to work as designed with the console.
Has anyone run into this situation before and found a solution? I am considering turning the throttle lever around 180 degrees but I am not sure yet if this would work correctly or not. Too tired tonight to figure anything out but was hopeful someone had dealt with this already. Jeff B |
wes |
Jan 5 2017, 10:50 AM
wes Group: Members Posts: 1,588 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California |
So is the tangerine Racing one different?
ChrisFoley |
Jan 5 2017, 11:44 AM
I am Tangerine Racing Group: Members Posts: 7,933 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Jonathan Livesay |
Jan 5 2017, 11:52 AM
Senior Member Group: Members Posts: 742 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
So is the tangerine Racing one different? It functions identically to the original, but mounts in a different place on the tunnel, thus eliminating interference with the console. Hmm, that one looks like it might work in my '66 912. I have one of Mark's on my '74 w/carbs and wanted one for my 912 but it would have to occupy the same space as the heater lever. There's no reason yours won't fit a 912 is there, Chris? |
ChrisFoley |
Jan 5 2017, 12:13 PM
So is the tangerine Racing one different? It functions identically to the original, but mounts in a different place on the tunnel, thus eliminating interference with the console. Hmm, that one looks like it might work in my '66 912. I have one of Mark's on my '74 w/carbs and wanted one for my 912 but it would have to occupy the same space as the heater lever. There's no reason yours won't fit a 912 is there, Chris? I don't know enough about the 912 tunnel to answer. |
Lo-Fi Version | Time is now: 24th May 2024 - 12:58 PM |
