Throttle Hand Lever Interference with Appearance Group Console, Does anyone have both of these options together? |
jkb944t |
Jan 3 2017, 08:17 PM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
I installed the throttle hand lever last night and then tried to test fit the appearance group console tonight. I found that the throttle lever is too far forward to work as designed with the console.
Has anyone run into this situation before and found a solution? I am considering turning the throttle lever around 180 degrees but I am not sure yet if this would work correctly or not. Too tired tonight to figure anything out but was hopeful someone had dealt with this already. Jeff B |
Dave_Darling |
Jan 3 2017, 11:35 PM
The Six was the only 914 with a hand throttle. The center console available on the Six was the "deposit box" type, and did not extend back to the shifter. So late console and the and throttle were never meant to go together.
Take Mark up on his offer; it will probably get you the nicest and cleanest solution possible. --DD |
mark04usa |
Jan 5 2017, 03:02 PM
'70 1.7 Tangerine Group: Members Posts: 351 Joined: 14-September 09 From: Austin TX Member No.: 10,805 Region Association: Southwest Region |
The Six was the only 914 with a hand throttle. --DD The 914/4 with Sportomatic option (a rare beast) also had the hand throttle. (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 08:49 AM |
