OT: Non skid, For concrete steps |
jeffdon |
Jan 4 2017, 01:37 PM
I need to apply a non-skid treatment to old concrete stairs that already have paint on them. The existng paint is in good shape. What all products have all ya'll used? Prefer a one part product.
Tom_T |
Jan 4 2017, 01:53 PM
IMHO a 2-part resin+hardener with a silica (sand) based grit is the long term best product type, & Home Despot, Lowes (& Highs), etc. sell them - but pick Behr, Pittsburgh Paints, or another top brand.
Consumer Reports does reports on paints available to consumers, but I don't think it covers this specialty product, but it will give you an ide of which manufacturers are making the better paints nowadays. IMHO the 1-part products won't harden like an epoxy or polyester with hardener product. Another option would be a good quality no-skid adhesive strip - IF the surface to which it is applied is smooth & clean for good adhesion. Again - pass on the Harbor Fright cheapo stuff, & get a quality manufacturer. Local property management supplies type stores will have that stuff, & the 2-part coatings as well. One of our members on here is a chemist, & hopefully he can weigh in with more detail. I can't think of his name offhand (dang half-zymers - maybe Rob??), but his avatar pic is Bill Murphy at the gopher hole from Caddy Shack! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
PlantMan |
Jan 4 2017, 02:17 PM
Member Group: Members Posts: 435 Joined: 14-May 14 From: Mission Viejo Member No.: 17,352 Region Association: Southern California |
I need to apply a non-skid treatment to old concrete stairs that already have paint on them. The existng paint is in good shape. What all products have all ya'll used? Prefer a one part product. You can check with Glaze-N-Seal or Miracle Sealants. Both have informative websites but you will need to apply these products after a couple years of use. They will not last forever. I have specified both on projects that I have designed and they do work. Good luck! |
wes |
Jan 4 2017, 03:08 PM
wes Group: Members Posts: 1,588 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California |
I just tape off the area you want none skid, paint that area, while still wet sprinkle desired amount of clean salt free sand let it dry. After dry add one more coat of paint. Works for me easy cheep, repaint as needed !
barefoot |
Jan 4 2017, 07:02 PM
Senior Member Group: Members Posts: 1,273 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
I need to apply a non-skid treatment to old concrete stairs that already have paint on them. The existng paint is in good shape. What all products have all ya'll used? Prefer a one part product. Go to Mcmaster Carr and look for tread tape, comes in rolls of about 60' and has great tape adhesion. Easy peasy. |
JeffBowlsby |
Jan 4 2017, 10:45 PM
914 Wiring Harnesses Group: Members Posts: 8,499 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
A rubber mat works... (IMG:style_emoticons/default/wink.gif)
Seriously, 99% sure you will need to remove the paint or at least abraid it to receive the new coating with aggregate in it. |
6freak |
Jan 5 2017, 09:05 AM
yeap there some bad ass peel and stick ,,should be ok clean the paint/steps with some miniral spirits....id wait for warm temps less your in Zona or something...its cold enough to freeze the balls off a brass monkey in the great PNW
(IMG:style_emoticons/default/smile.gif) |
mbseto |
Jan 5 2017, 09:20 AM
Senior Member Group: Members Posts: 1,253 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
Indoors or outdoors?
jeffdon |
Jan 5 2017, 02:52 PM
jeffdon |
Jan 5 2017, 03:15 PM
914GT |
Jan 5 2017, 04:05 PM
Senior Member Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
One option you could consider is this deck and patio coating. I applied this non-slip coating over my old kool-deck area around my pool and it has been holding up well for years. It gets a lot of abuse from my two grandsons and the dogs, along with our intense Arizona sun and occasional cleaning with a pressure washer. Leslies Pools carries it, as well as possibly other pool supply places.
http://smartsealco.com/products/patioperfect.asp |
Lo-Fi Version | Time is now: 12th May 2024 - 03:45 AM |
