fuel pump removal for '74 1.8 |
mikehinton |
Jan 6 2017, 01:21 PM
Newbie Group: Members Posts: 4 Joined: 17-May 11 From: St. Helena, CA Member No.: 13,081 Region Association: Northern California |
I'm in the process of trying to replace the fuel pump on my 1074 1.8. Is there some secret method to loosening the clamp that holds the pump to the body? I can't figure out how to access the bolt that tightens the clamp.
Thanks in advance! |
napasteve |
Jan 7 2017, 10:31 AM
914 driving winemaker Group: Members Posts: 503 Joined: 2-January 13 From: Napa, CA Member No.: 15,327 Region Association: Northern California |
Mike,
If your fuel pump is like my original, you need a 1/4" drive with an extension to get the nut off. It's tight but doable. I don't remember what the nut size was; maybe 10 or 12mm? Here is a picture of my original fuel pump. Obviously you need to remove the flapper before you can get at the pump. |
mikehinton |
Jan 7 2017, 05:16 PM
Mike, If your fuel pump is like my original, you need a 1/4" drive with an extension to get the nut off. It's tight but doable. I don't remember what the nut size was; maybe 10 or 12mm? Here is a picture of my original fuel pump. Obviously you need to remove the flapper before you can get at the pump. Hi Steve: I was able to get the upper bolt, but couldn't access the lower one. I wound up just cutting the clamp with a Dremel tool. I'm going to rig up another mounting system to make the job easier next time! Mike |
napasteve |
Jan 7 2017, 06:20 PM
Lo-Fi Version | Time is now: 12th May 2024 - 03:26 AM |
