QUOTE(napasteve @ Jan 7 2017, 08:31 AM)
Mike,
If your fuel pump is like my original, you need a 1/4" drive with an extension to get the nut off. It's tight but doable. I don't remember what the nut size was; maybe 10 or 12mm?
Here is a picture of my original fuel pump. Obviously you need to remove the flapper before you can get at the pump.
Click to view attachmentHi Steve:
I was able to get the upper bolt, but couldn't access the lower one. I wound up just cutting the clamp with a Dremel tool. I'm going to rig up another mounting system to make the job easier next time!
Mike
